3SGTE issues
3SGTE issues
Postby headshotnz » Sat Oct 19, 2013 12:54 pm
Hi guys, What ideas do we have?
Symptoms: Vacuum gauge reading -18.5 (3sgte's idle @ -20(Generally))
Choppy idle, quite possibly missing.
Last week I noticed straight away as I pulled up my driveway that the vacuum was higher than normal, so i took it for another quick run. Max boost was 6psi and was very slow to get there.
I had a quick check for vacuum leaks, couldn't find any thing, parked her up for the week.
Today I went back out, turned her on, once warm same problems. fiddled around, felt and listened for vacuum leaks.Nothing. Tightened all air hoses. Nothing. Took her for a drive, would now boost over 6 psi, but was very slow to get there and would start missing at 5k revs.
In the interim I tried changing the BOV in case it was leaking. No change.
I might add 2000kms (at a maximum) I changed the Spark plugs and leads for new genuine parts.
Since the head/headgaket/cambelt/putting a ct26 back on job(same time as leads and plugs). It has been running great untill now.
Ideas????
Ta
James
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Dell'Orto » Sat Oct 19, 2013 7:12 pm
Cracked piston. Does it blow smoke?
Postby iOnic » Sat Oct 19, 2013 7:49 pm
Do a boost leak test to eliminate vac leaks then Do a leak down test. Could have hit a valve and it has progressively burnt out from not seating right.
Postby matt dunn » Sat Oct 19, 2013 7:53 pm
blocked exhaust ?
Postby rollaholic » Sun Oct 20, 2013 9:11 am
yeah take the exhaust off and go for a wee drive. will be fun if nothing else :P
Postby headshotnz » Mon Oct 21, 2013 1:31 pm
Dell'Orto wrote:Cracked piston. Does it blow smoke?
No more than a well maintained 200+km turbo car will smoke.
headshotnz
Postby headshotnz » Mon Oct 21, 2013 1:33 pm
iOnic wrote:Do a boost leak test to eliminate vac leaks then Do a leak down test. Could have hit a valve and it has progressively burnt out from not seating right.
Hmm its worth a check. I'm also wondering if it has skipped a tooth on the cambelt.
Some one should just buy it from me. job done.
headshotnz
Postby GDII » Mon Oct 21, 2013 2:26 pm
Can I buy the SW20 instead? Maybe I could use the GT4 engine in my car....
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby headshotnz » Mon Oct 21, 2013 10:03 pm
haha make an offer.
headshotnz
Postby GDII » Mon Oct 21, 2013 10:25 pm
When did it turn Matte black? My offer would probably be too low and I wouldn't be allowed to buy another one, quite keen on a turbo engine for my current SW though.
1990 SW20 MR2
GDII
Postby headshotnz » Mon Oct 21, 2013 10:36 pm
It always has been. You must have seen my other one ;)
The tri's I have kept and will be going on the matt black 2.
headshotnz
Users browsing this forum: No registered users and 45 guests
