Anyone know where to get a 12x1.25 banjo bolt with a pipe thread or barb fitting out the top of it locally.
Like this
Scottie wrote:Thanks, but hydraulic fittings are not 12x1.25. I think I may end up having to make something.
allencr wrote:Brazing can be good for thousands of PSI, soldering can easily handle a fuel pump unless it's a poor mechanical joint and a poor solder joint.
