Vertigo wrote:Strangely the two wires for the starter are ok. Its possibly the engine bay temp sensor wiring, or the engine water temp sensor wiring, both in the same part of the loom. Jiggling these wires gives shorting sounds and relays firing, and occasionally the fans all come on and the engine check light also.
Then Ill leave them alone, and for no reason everything stops.
Users browsing this forum: Bing [Bot], Google [Bot] and 56 guests
