FST4RD wrote:Hi all, have couple questions hope I can get answered.
Do 1jz and 2jz share the same mountings? YESIe are they interchangeable?YES, the 2jz block is ~40mm taller so need more bonnet clearance.
Do they all share the same gearbox mountings?YES, Same Bellhousing bolt pattern
I understand that they come with different sumps?YES/NO, Both come in front & rear sump variants
Are the auto and manual ones different?NO, Base engines are the same, 2JZ's come with bigger torque convertors than the 1JZ's (for *GTE's) AFAIK
Did a quick search, but couldn't find exactly what I was looking for.
Mr Ree wrote:Just keep in mind that the vvti 2JZGE has weaker rods than the non vvti GE, incase you were thinking about performing an na-t conversion down the track.
Mr Ree wrote:The vvti GE is a great motor, and would be enough for most people, especially in a sub one ton car.
I only mentioned the rods because you mentioned a turbo lol
They are easy to na-t, but not cheap if you want to do a nice job of it.
Although in saying that, if you were happy with circa 280 whp, you could just keep the engine sealed, add a walbro, and have a nice peppy high compression build on your hands.
Will you be running an R154?
FST4RD wrote:Car is going to be built for track, already has rollcage etc.
So would be mildly worked vvti motor have the ability to role a w series box? Or am I better going straight for the r154?
Users browsing this forum: No registered users and 33 guests
