AE86 whiteline front bar question
Postby GOLDAE86 » Thu Nov 14, 2013 9:25 pm
Bought one recently for the RC. Went to test fit it to day and the mounting points wouldn't line up etc. Anyone had any issues or come across this before?
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby malc » Fri Nov 15, 2013 10:31 am
I had issues fitting my one, it was a bit of messing around to get it all lined up properly.
I had to make the holes in the sway bar brackets that attach to the frame bigger so the bar would not foul at those points. Also the sway bar sat further out on the left side by about 50-60mm than compared to the right.
I still need to get it sorted out as I have found that it actually fouls the brake caliper on full lock.
Not sure if they are all like that or just a bad batch.
malc
Postby GOLDAE86 » Fri Nov 15, 2013 10:35 am
Im thinking bad batch as my mounting points on the bar are miles out
GOLDAE86
Real Life Mechanic
Postby malc » Fri Nov 15, 2013 10:55 am
When did you get yours? I bought mine a few years ago, maybe they are still making them out of shape
malc
Postby GOLDAE86 » Fri Nov 15, 2013 11:39 am
Bout 2 months ago
GOLDAE86
Real Life Mechanic
Postby Mr Revhead » Sat Nov 16, 2013 11:47 pm
Make sure its not wrong one in the box. Had that a few times!
Postby GOLDAE86 » Sun Nov 17, 2013 12:10 am
Seemed to be the right one just wider at the mounting points.
GOLDAE86
Real Life Mechanic
Users browsing this forum: Google [Bot] and 27 guests
