Brake dust removal tips
Postby Mr Ree » Fri Dec 13, 2013 4:26 pm
Hey TS'ers :)
I have some Volk TE37 track rims that are in the preparation stage of Plast-dipping, and I was hoping some of you might have some good suggestions for the removal of ingrained brake dust/road grime.
I have tried extremely hard to remove it over the past week, everyday a different product/method, and unfortunately getting very poor results.
I bought a bottle of Wax and grease remover, which was suggested as the main product you need to use before applying Plasti-dip, but this isnt doing anything to the brake dust.
Next, I tried a various selection of polishes, which I had a fair amount of success with when I restored my CE28N's a few years back (hand polished back to brand new over 2 or 3 weeks), and TBH, they were extremely filthy too, not to mention covered in over spray, so Im guessing the difference is the brake compound material.
So I then tried petrol on a small area, and still, no dice.
Next up, Simple Green, as advised from 1,000,001 google threads, but not much of a result there either :(
Im not shy when it comes to spending rediculous amounts of time on things, so they come out as close to perfect as possible, so this isnt a case of trying to find the easiest way out with a miracle product, but Im all ears if you have any suggestions.
wak thud gush!
Mr Ree
Re: Brake dust removal tips
Postby Grrrrrrr! » Fri Dec 13, 2013 5:10 pm
Water blaster and clay bar?
Grrrrrrr!
Postby whynot » Fri Dec 13, 2013 5:13 pm
I would try something like Jiff
whynot
Postby Mr Ree » Fri Dec 13, 2013 5:14 pm
I hadnt considered using my water blaster to be honest...Im always quite cautious of WB's and cars, incase it strips back the paint/clearcoat/finish etc. I would have zero concerns doing this to the steelies on the Camry, but... Have you used one on this type of wheel before?
Without even trying, I know the claybar wont make a dent in it, as I used claybar on the CE28N's and it was only good for removing the over-spray. But I will still try again haha ;)
Thanks for the suggestions,
wak thud gush!
Mr Ree
Postby Mr Ree » Fri Dec 13, 2013 5:16 pm
whynot wrote:I would try something like Jiff
Cheers for that.
Ill carefully give it a go, given how abrasive it is, but none of my various polishes/compounds had any success.
wak thud gush!
Mr Ree
Postby Grrrrrrr! » Fri Dec 13, 2013 5:26 pm
Use a more agressive coumpound, if that has'nt had any effect then sandpaper/blasting + paint/powdercoat is probably the only answer.
Grrrrrrr!
Postby jondee86 » Fri Dec 13, 2013 6:07 pm
In another forum, far... far... away... Justin said this....
Export degreaser and a soft brush followed by hosing with a pressure
washer does wonders for getting baked on brake dust off of wheels for me.
If it doesn't work... blame Justin :)
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Mr Ree » Fri Dec 13, 2013 6:12 pm
Ive used 6 different polishes/compounds and tbh, I cant see a more aggressive compound working.
Sanding isnt really a consideration at the moment, mainly due to the fact that the whole point of the plasti-dip was that I can return the wheels to their original appearance once the dip starts looking tatty.
Im going to try your WB suggestion next week, and will report back with my results :)
Jondee86, thanks for that, but sadly, this is far beyond the ability of degreaser
wak thud gush!
Mr Ree
Postby Bling » Fri Dec 13, 2013 7:51 pm
I've just used SCA degreaser spray cans in the past, then a tooth brush. Not many options when trying to clean Advanti Stilettos. Is it engrained into pits on the wheel surface or is it smooth?
Postby Crucible » Fri Dec 13, 2013 8:35 pm
Hey mate,
Have you considered brakleen?
The CRC blaster stuff is the best IMO and will take grease/brake dust off rotors without the use of a rag etc. If you need something more potent go with the Prestone brakleen, really toxic stuff!
Crucible
Real Life Mechanic
Postby Mr Ree » Fri Dec 13, 2013 8:49 pm
Bling wrote:I've just used SCA degreaser spray cans in the past, then a tooth brush. Not many options when trying to clean Advanti Stilettos. Is it engrained into pits on the wheel surface or is it smooth?
I have some here so will give that a go, just to try it out. The wheels are 13 years old, so definitely engrained into the pits :(
Crucible wrote:Hey mate,
Hey mate,
I havent tried Brakleen yet, actually. Its starting to get expensive buying all these products lol
Ill pick some up on my way out to work on my car tomorrow, as I think repco is having a 25% off sale
Thanks guys :)
wak thud gush!
Mr Ree
Postby Bling » Fri Dec 13, 2013 8:52 pm
Yeah brake clean is heaps more than the degreaser. It's better though, so will be a case of seeing the minimum that works. I don't waste my brake cleaner on wheels that's for sure. :lol:
Postby ch4ng » Fri Dec 13, 2013 8:59 pm
Head to your local car groomers/ panelbeaters supplies shop.
Tranzbrite.co.nz do a product called Hot Rims which I've used with great success in the past. It's concentrated so you can water it down for normal wheel cleaning in the future.
http://www.tranzbrite.co.nz/4922.html
or for something stronger
Pacer.co.nz do a product called "Supa-Rip" This is an amazingly strong degreaser and cleaner. Caution is advised with this one though. Don't let it sit on your paintwork for too long or it can stain/damage it. (30 sec is usually enough so do small portions at a time.
http://www.pacer.co.nz/shop/product_inf ... a02ab4638b
Tranzbrite also supply an equivalent they call "Monsta-Rip" so go for whichever is more cost efficient. You can buy them in 4L, 20L or 200L :P
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Mr Ree » Fri Dec 13, 2013 9:41 pm
Thanks, Chang.
Ill see how I get on with the other methods first, before getting the wallet out again, but I appreciate the info :)
wak thud gush!
Mr Ree
Postby jbod » Sun Dec 15, 2013 8:50 am
+1 on jiff. Had excellent results after not washing wheels for 2 years.
jbod
Postby JZCrazy » Sun Dec 15, 2013 9:30 pm
Have just cleaned up a set of TE37s. Yesterday.
Washed in hot soapy water with a stiff brush to remove excess dust.
I used Chemico (the pink stuff in the pink tub) with a tiny amount of water and 00 steel wool. Jif might be similar
Took about 3 hours per wheel. Don't rub too hard for too long. Take your time.(sore fingers)
I did try brakekleen but it seemed to make things worse.
The problem isn't the brake dust but what is under it, tar spots. a right kent to remove.
JZCrazy
Postby Mr Ree » Mon Dec 16, 2013 9:30 am
Im never that aggressive with cleaning things, especially anodized metal. ;)
With everything I detail, I always try and go from the least aggressive point and work my way up, as once you use steel wool, the wheels are covered in micro-scratches from the wool, they will soak up dirt far easier in the future
Where did you get the Chemico from please, Evan?
wak thud gush!
Mr Ree
Postby JZCrazy » Mon Dec 16, 2013 8:03 pm
Chemico is/was available from any supermarket. I have had it sitting around for a while.
The 00 steel wool is the finest stuff, yeah rub to hard and it takes the top of the anodising of.
Might need to buy a can of bronze spray. (Me).
JZCrazy
Postby Mr Ree » Mon Dec 16, 2013 11:56 pm
The Volk colour is quite hard to find from memory, but I remember visiting a site that sold it for refurbs.
Ill have a dig and see what I find :)
wak thud gush!
Mr Ree
Postby RobertC » Tue Dec 17, 2013 12:05 am
if the stuff is that ingrained into the surface its probably pretty stable so why not just put the plasti dip over it..?
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Users browsing this forum: Bing [Bot], Google [Bot] and 36 guests
