Throttle vs boost.
Throttle vs boost.
Postby steroidcontaskie » Mon Dec 23, 2013 11:51 pm
Hi all,
limbo and I have been playing cars and doing a bit of test driving / logging on my soarer that is only tuned up to 4000rpm (trans let go after that on the dyno). A couple of question popped up during the test run.
So, the logs say I am getting 4psi at 3500rpm at around 50% throttle, and I was wondering will the turbo spool up much faster when I give the car 100% throttle? More specifically, is there anyway to figure out about when I would get 9 psi with 100% throttle?
Cheers Edward.
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Re: Throttle vs boost.
Postby QikStarlie » Tue Dec 24, 2013 12:55 am
get it tuned properly and find out?
QikStarlie
Postby evil_si » Tue Dec 24, 2013 6:02 am
Turbo needs exhaust gas to spool, in turn you need fuel to create the gases,
So yes 100% throttle will see much faster spool
evil_si
Postby Flannelman » Wed Dec 25, 2013 10:23 pm
evil_si wrote:Turbo needs exhaust gas to spool, in turn you need fuel to create the gases,
Not quite true. Turbo spool works on engine load, not throttle position. As with no load, 100% throttle will see 1-2psi yet 100% load with 10-20% throttle will easily generate full boost.
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
