Brake conversion help
Postby finder066 » Mon Dec 30, 2013 1:32 pm
Hi guys
I have a starlet glanza s which has drum brakes in the rear and i would like to swap in disc brakes from a glanza, obviously ill need the discs but will i need the brake booster and is there anything different about the rear suspension setup including the axle in a glanza v that would make this difficult?
Thanks
finder066
Re: Brake conversion help
Postby Grrrrrrr! » Mon Dec 30, 2013 2:41 pm
You'll also want the proportioning valve off the disc brake car.
Grrrrrrr!
Postby finder066 » Tue Dec 31, 2013 12:50 pm
ok so just grab the master cylinder assembly from a glanza v then?
finder066
Postby Bling » Tue Dec 31, 2013 1:03 pm
Are the Glanza V front discs and calipers the same as the S?
Postby molex » Thu Jan 02, 2014 1:02 pm
You'll need to swap the whole rear axle to swap to discs. You will need handbrake cables, prop valve and master cylinder, booster should be the same. Also remember to get hoses for the rear as they'll be different too.
Why?
molex
Users browsing this forum: Bing [Bot] and 38 guests
