What vac lines are these?
Postby Frogo » Thu Jan 09, 2014 4:18 pm
Can someone please help me point out where these pair of vac hoses go on a 4age 20v BT in a AE82. I have had a look on toyodiy but can't find anything conclusive. I'm thinking its for the power steering, but can't seem to find the mounting bracket point. Also in the pic the right hand hoses have been cut off so not sure of true the length.
Any help much appreciated.
Frogo
Re: What vac lines are these?
Postby Bling » Thu Jan 09, 2014 4:36 pm
Closest I could find, no longer have a 20v to check on sadly. But looks quite similar to the bottom section?
http://www.toyodiy.com/parts/p_J_1996_T ... 708.5.html
Postby Frogo » Thu Jan 09, 2014 6:01 pm
Definitely not p/s as I have just found those 2.
Bling wrote:Closest I could find, no longer have a 20v to check on sadly. But looks quite similar to the bottom section?
I think that one has 3 hoses and no mounting point? Will see if I can find that vac switch to confirm. Thanks
Frogo
Postby Frogo » Thu Jan 09, 2014 7:34 pm
Sorted. Those were actually the p/s vac lines from the ae82 rack :oops:
Frogo
Postby Bling » Thu Jan 09, 2014 7:39 pm
At least you worked out what they are from :lol:
Users browsing this forum: Bing [Bot], Google [Bot] and 40 guests
