Girvs wrote:Getting 6.3 litres per 100Km from my RAV....admittedly is a 2008 diesel.
Alex B wrote:I'm pretty sure the previous model Diesel could be purchased NZ New as well as the latest one.
Dad launches and tows his 5M crestacraft with a 2008 Rav
Lloyd wrote:http://www.rav4.co.nz/diesel/overview/
And every private diesel Rav4 on trademe seems to be NZ new actually.
Girvs wrote:Finished galavanting like a long haired hippy. TBH I'm content with mine. Its fairly economical, apparently averaging 6.4 litres per 100KM atm, or so it tells me. As for towing, I towed a furniture trailer (single axle) and averaged about 9.5L/100KM (which is 0.1l/100KM more efficient than my NA Supra has ever been). and it was about 8l/100KM with an unladen trailer. As for pulling up hill with a trailer it was a piece of piss, sure I had to down shift, but I held about 90km/h uphill no worries at all, the torque is fantastic
Yes, its marginally smaller than the J-Spec (40mm), but its ok'ish size wise. The handling I'm very impressed with and its quite stable on the road. Has dual climate air control which is handy and you can disable the passengers airbag if need be.
If there's any downers about it, its that it costs so much to own a diesel in NZ. About $400'ish to register plus RUC's. The stereo doesn't have any Aux in or bluetooth so no handsfree.
Bought it at 82,XXXX and now upto around about 111,XXX. Most of those K's are put on it from driving to/from Kune in the winter season and up the mountain and its very comfortable to drive in. Not sure if theres any other questions I can answer, technically I haven't had anything go wrong with it, though its had two factory recalls. One for the window motor and the other for the rear upper suspension arm IIRC.
