shogun wrote:Did you end up fixing yours?
gepsk8 wrote:I had noise in my car only light acceleration in 3rd and 4th.
Ending up two years later wheel bearing got really bad,
So I would do wheel bearing before touching gearbox
Also check muffler baffles being loose.
Mr Revhead wrote:I'd have thought it would be pretty easy to hear the difference in location between gear box and wheel bearings.
More likely removing the axles has decreased the load so there isn't enough to make the rattle.
matt dunn wrote:Solid Centre clutch?
Sounds like it too me, has been struck here a few times,
shogun wrote:Did a quick search and the description of the noise is similar but mine does not rattle under deceleration.
Users browsing this forum: Google [Bot] and 49 guests
