Diff 'sticking'
Diff 'sticking'
Postby cat007 » Fri Jan 24, 2014 2:24 pm
Hey all
just pulled the diff from my supra as it was making some noises.
I thought it sounded more like a preload problem - and could still be - but the symptoms out of the car make me think it's a bearing issue.
Turning the input flange it's 'very' hard to start it turning. Once it's turning it's very rough. Seems fine when turning either side individually. But when turning the front it's quite rough.
I'm assuming this is a bearing up the front that's perhaps gone dry (long motorway (ahem, I mean race track) pulls could be starving the front bearing)?
Is anyone on the shore around this afternoon/evening to come give a quick diagnosis? I'm careless at the moment so can't come to you....
Re: Diff 'sticking'
Postby jbod » Fri Jan 24, 2014 6:38 pm
Without pulling apart is difficult to diagnose but you are probably on the money the bearing is worn. I wouldnt think because of pulls on the motorway tho. Just the nature as it wears out. Have a new set put in. The preload shouldnt be wrong unless you have recently replaced them and incorrectly set the clearance between cup and cone.
jbod
Re: Diff 'sticking'
Postby limbo » Sat Jan 25, 2014 1:37 pm
I pulled my diff as I was repairing the subframe, took it in to get re shimmed as it was fine but lsd didnt do much, no noise, turned fine by hand, no problems at all other than the ls....probably had been like that since I have owned the car.
Yet here you go... so the only way is to pull it to bits.
limbo
Re: Diff 'sticking'
Postby cat007 » Sat Jan 25, 2014 1:40 pm
Wow that looks toast.
I'm running a Torsen though so the insides are a little different
Re: Diff 'sticking'
Postby jbod » Sat Jan 25, 2014 4:00 pm
Whip it apart! If your lucky ill get you some bearings cheap.
jbod
Re: Diff 'sticking'
Failing that take it to steelie gears. Tony will sort you out he charges more than reasnable prices!
jbod
Re: Diff 'sticking'
Postby cat007 » Sat Jan 25, 2014 5:53 pm
Well got it mostly apart - but for the life of me I can't get the drive pinion out of the diff housing.
Taken the front nut off - and tried hammering and pressing the pinion out towards the rear of the diff. Doesn't seem to want to move and I don't know how much pressure I can apply to it.
Anything I'm missing? I can't see any C clips or anything holding it in....
Re: Diff 'sticking'
Postby cat007 » Sun Jan 26, 2014 8:59 am
Got it - sledge hammer to the rescue haha
Re: Diff 'sticking'
Postby iOnic » Sun Jan 26, 2014 2:23 pm
Don't $&#$% the thread on the pinion. That always makes life fun.
Re: Diff 'sticking'
Postby cat007 » Sun Jan 26, 2014 2:25 pm
iOnic wrote:Don't $&#$% the thread on the pinion. That always makes life fun.
hah yeah I bet. Was making sure I didn't.
Users browsing this forum: Bing [Bot] and 39 guests
