Dyno graph - what happened??
Postby cat007 » Sat Mar 08, 2014 1:24 pm
What do you all think happened on this dyno graph of my Supra? Why did it drop off so sharply at the end, yet the boost and AFR stay as steady as they had been previous...?
Maybe a bit of wheelspin on the dyno?
She is certainly running pretty rich though.
Re: Dyno graph - what happened??
Postby d1 mule » Sat Mar 08, 2014 8:35 pm
would also be questioning why it only made 240 whp
d1 mule
Postby cat007 » Sat Mar 08, 2014 8:46 pm
d1 mule wrote:would also be questioning why it only made 240 whp
Yeah something is *not* right. Not sure what. Wasn't missing. Is running a bit richer than my original 238rwkw dyno.
I have a feeling the timing is way off as I think my harmonic balancer had spun on its rubber. Seems to be about 5-7 degrees out.
Edit: something is *not* right
Postby Dell'Orto » Sat Mar 08, 2014 9:41 pm
Man is that super laggy or did they not rev it right out? I would hazard a guess given your latest questions that your cam timing is out :lol:
Postby cat007 » Sat Mar 08, 2014 10:10 pm
Dell'Orto wrote:Man is that super laggy or did they not rev it right out? I would hazard a guess given your latest questions that your cam timing is out :lol:
It could that the cam timing is out. I will check #1 pistons TDC and compare it to the cam's alignments.
Here's a scan of my old dyno sheet. Much nicer fuel, and power, and torque. Everything really haha
Postby cat007 » Sat Mar 08, 2014 10:12 pm
And the run from today if anyone's interested:
http://youtu.be/wPKrtfudFOQ
Postby iamawesome » Sun Mar 09, 2014 8:17 am
Seems very odd, did Geoff tune it at all? And just out of curiousity, how did you get put on to him?
iamawesome
Postby cat007 » Sun Mar 09, 2014 8:19 am
iamawesome wrote:Seems very odd, did Geoff tune it at all? And just out of curiousity, how did you get put on to him?
It was a supra club dyno day. So no tuning. Just a power run.
Postby Dell'Orto » Sun Mar 09, 2014 11:24 am
Yeah look how much later it makes full boost now. Either timing is out or its lost lots of compression
Postby cat007 » Sun Mar 09, 2014 1:15 pm
Dell'Orto wrote:Yeah look how much later it makes full boost now. Either timing is out or its lost lots of compression
Hmm. Guess I should find a compression tester...
Postby Flannelman » Sun Mar 09, 2014 4:05 pm
Whats been changed since the dyno runs?
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby cat007 » Sun Mar 09, 2014 4:12 pm
Flannelman wrote:Whats been changed since the dyno runs?
Vavle Springs and about 6 years of it sitting around. Probably only about 10k on the clock...
Postby Flannelman » Sun Mar 09, 2014 4:25 pm
Whats the new spring rates?
New valve springs mean cam removal. I would be checking cam timing closely, (the intake cam could be retarded one tooth) followed by correctly adjusted throttle - is it getting 100%? No blockages in intake track? Are the air cleaners clean?
Flannelman
Postby cat007 » Sun Mar 09, 2014 4:48 pm
Flannelman wrote:Whats the new spring rates?
I can't remember the specs exactly but they're matched to the TRD equivalent apparently.
I will double check cam timing.
Throttle position idle and full is adjusted correctly.
No blockages in the intake and the air filter isn't perfect but not exactly dirty either...
Postby Flannelman » Sun Mar 09, 2014 5:10 pm
Just a tip, use a long thin screwdriver down the spark plug hole to see where TDC is if the timing marks are suspect.
Flannelman
Postby cat007 » Sun Mar 09, 2014 5:12 pm
Flannelman wrote:Just a tip, use a long thin screwdriver down the spark plug hole to see where TDC is if the timing marks are suspect.
Yeah will do
I'm pretty certain my crank pulley has spun on its rubber so that'll have put the timing off if it has
Postby QikStarlie » Sun Mar 09, 2014 5:22 pm
use the piston stopper method i suggested awhile back. screw driver trick should tell you if its out, but isn't very accurate for setup.
if everything else checks out timing wise both ignition and cam timing. i would start to look for a boost leak
QikStarlie
Postby JZCrazy » Sun Mar 09, 2014 8:51 pm
What gear was it Dynoed in?
JZCrazy
Postby cat007 » Sun Mar 09, 2014 8:52 pm
JZCrazy wrote:What gear was it Dynoed in?
4th
Postby JZCrazy » Mon Mar 10, 2014 12:36 am
Oh hmm
JZCrazy
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
