Kiwi6539 wrote:Cheers for reply
I'm guessing worn but will look at changing oil I put in. Was for lsd.
What oil or mix how you found best for viscious lsd?
Racing Sunday
sergei wrote:I believe that viscous when wears out it will become stiffer not other way around.
mega4a wrote:but the viscous does work off the oil doesn't it ? like the dude explains in the video I posted and the viscous plates wear down after time. and the viscous lsd is made to one wheel like in corners one wheel will be spinning faster than the other so it has to act like an open diff but in a straight line it will two wheel.
if it was a sealed unit what would be the point of axle seals and why does oil leak out from the diff if i was to pull an axle out ?
mega4a wrote:but the viscous does work off the oil doesn't it ? like the dude explains in the video i posted and the viscous plates wear down after time. and the viscous lsd is made to one wheel like in corners one wheel will be spinning faster than the other so it has to act like an open diff but in a straight line it will two wheel.
