Tial q blow off valves
Postby mega4a » Sun Mar 09, 2014 1:25 pm
hey guys jut wondering for those out there that have used the tial q 50mm what spring did you use the chart says use a dark pink for -20in/hg but i have a 10 psi in mine what it come with from the shop and i still get abit of compressor surge .
DAILY DRIVEN.
230HP ATFW AE100 WAGON 4AFTE MEGASQUIRT.
1999 Toyota Corolla BZ Touring wagon 4age 20v bt.
1996 Toyota Truneo 5AFE
mega4a
Re: Tial q blow off valves
Postby Mr Ree » Mon Mar 10, 2014 3:30 pm
Is the surge happening under acceleration, or vacuum?
wak thud gush!
Mr Ree
Postby mega4a » Mon Mar 10, 2014 5:16 pm
the surge happens when change gear and come off the throttle it has a tiny bit of surge then a pssssht noise so blow off is working just seems delayed i do have short piping and ball bearing turbo maybe i can't get away from having a lil bit of compressor surge ? the blow of valve has its own vacuum line and is a bigger vacuum line 6mm inner diameter
DAILY DRIVEN.
mega4a
Postby Soiled » Mon Mar 10, 2014 7:27 pm
I had the same problem with mine, and am ordering a softer spring to see if it makes a difference once I get my car back on the road.
Soiled
Postby matt dunn » Mon Mar 10, 2014 8:05 pm
I run a tial BOV on my race car and had to get a super soft spring it it to get it to open properly,
just not quite open at idle, but opens really quickly and early,
but no noise as it's mounted underneath the inlet manifold.
Postby mega4a » Mon Mar 10, 2014 8:34 pm
They are quiet sounding blow off valve its a good thing i think. i guess cause it is 50mm. what spring did you guys go with ? i was thinking of trying the 9 psi one which is meant to be according to Tial for 14in/hg-17in/hg vacuum.
DAILY DRIVEN.
mega4a
Postby MrOizo » Mon Mar 10, 2014 9:03 pm
Have you measured your vacuum at idle?
MrOizo
Toyspeed Legend
Postby mega4a » Tue Mar 11, 2014 8:11 am
yes of course when my car is cold i get about 20in/hg when hot i get 22in/hg
DAILY DRIVEN.
mega4a
Users browsing this forum: Google [Bot] and 37 guests
