DIY air jack?
DIY air jack?
Postby cat007 » Wed Mar 12, 2014 10:22 am
Has anyone ever thought of making an air jack out of something like this:
http://www.trademe.co.nz/motors/car-par ... 636315.htm
Not sure how much pressure they need, but I bet it wouldn't be hard to use a dive bottle and regulator. Quick and easy and portable solution to jack your car up at the track?
Re: DIY air jack?
Postby Grrrrrrr! » Wed Mar 12, 2014 10:45 am
Airbags would require guidance, and travel limiting. Also need to make sure there is no way they can extend while on track. Hitting a ripple strip and having an airjack drop and dig in would be seriously not good.
Grrrrrrr!
Re: DIY air jack?
Postby cat007 » Wed Mar 12, 2014 10:47 am
Grrrrrrr! wrote:Airbags would require guidance, and travel limiting. Also need to make sure there is no way they can extend while on track. Hitting a ripple strip and having an airjack drop and dig in would be seriously not good.
I meant something like this:
http://www.trademe.co.nz/motors/car-par ... 297222.htm
Not sure if that is using an old air bag, or if it's a specific type of bag....
But buying an air bag to make something like the above trademe link would be a cheap alternative?
Re: DIY air jack?
Postby iOnic » Wed Mar 12, 2014 12:28 pm
Same problem as other pneumatic jacks. They don't fit under anything worth having on a track.
Re: DIY air jack?
Postby Bling » Wed Mar 12, 2014 12:45 pm
Just set off airbags and get faster at swapping wheels before it hits the ground.
I can't see it being worth the hassle though really.
Re: DIY air jack?
Postby Rick » Sat Mar 15, 2014 11:07 am
I like the idea of these, I would feel a lot safer working under the car, but I guess it depends if you need a rapid pit stop or not.
