ae101 4age silvertop auto intermittent issue...
Postby h8wrxs » Tue Mar 18, 2014 11:59 pm
my sister has an ae101 trueno (auto ewww)
its started to crap out a few days ago, the motor just dies all of a sudden for no aparent reason
it does it when the engine is hot and cold so that doesnt help me narrow it down
every time ive tested it it seems to have spark on all the plugs
ive spoken to one of my mates whos an auto sparky, he has narrowed it down to either being a faulty ecu, or a faulty pickup in the dizzy,
he's tested the dizzy at work for me but sitting on the bench it tested fine? but when attached to a running motor im wondering if that would be different
basically im asking are either the distributor/cap or ecu a common problem on 4ages? ive had a few truenos/levins and ive never heard of either being a problem or come across it before?
thanks
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Re: ae101 4age silvertop auto intermittent issue...
Postby jaypines » Wed Mar 19, 2014 12:11 am
check if you have fault codes in the ECU. if a faulty ECU, check for leaking capacitors inside(due to old age).
check the fuel pump as well including circuit opening relay.
jaypines
Postby Grrrrrrr! » Wed Mar 19, 2014 1:00 am
Ecu is a reasonably common problem, ive had two that developed dodgy ECUs. Pull the cover off and look for leaky or swollen caps.
Grrrrrrr!
Postby Crucible » Wed Mar 19, 2014 8:58 pm
So you need to see what your loosing when it stops.
Start with fault codes, do you have eng check lamp key on engine off?. Direction, do you have fuel pressure, ignition?
Start there first.
Crucible
Real Life Mechanic
Postby KinLoud » Thu Mar 20, 2014 10:46 pm
Pretty sure that no codes show when the ecu is failing
Postby matt dunn » Thu Mar 20, 2014 11:59 pm
KinLoud wrote:Pretty sure that no codes show when the ecu is failing
ECU's are super common to fail.
Sometimes they bring up fault codes that don't exist,
sometimes they don't bring up any codes,
and sometimes the Check light doesn't even come on.
I would say the ECU is more likely to be faulty than the sensor inside the dist by a long way.
Postby Crucible » Fri Mar 21, 2014 12:29 am
Reason i asked if there was a check lamp with key on.
have come across this on a few occasions and ended up being ecu, and yeah one had no codes but was buggered.
Crucible
Real Life Mechanic
Postby h8wrxs » Sat Mar 22, 2014 7:38 pm
cheers for your tips the other day
it was showing no fault codes
it ended up being a blown capacitor on the ecu which was an easy fix
h8wrxs
