Kiwi-Corolla wrote:I strictly only ever put in $20 at a time, mainly because the less weight you have to haul the less gas you'll use, and by consistently putting in the same amount I can see if my fuel economy ever changes by seeing how many km's I get before the fuel light flashes on again.
Lloyd wrote:$20 is less than 9L. So basically 100km between fills. Seems like a waste of time.
Grrrrrrr! wrote:Also hilarious argument about minimising weight for fuel economy in a car with every JDM gadget known to man.
GDII wrote:Do you have to go out of your way to get the $20 each time or is the petrol station always on your route from home to where ever? I used to do the same thing as you do but that was only because the petrol station was at the end of the street and if I had to go anywhere I had to pass it. Also $20 used to go a lot further than it does now.
sergei wrote:That is very innacurate way of measuring fuel economy. To start with I could make fuel light come on with 1/4 of tank on AE101. Second problem $20 every time does not equal same amount of fuel. Third the weight of fuel makes very little difference.
