Dell'Orto wrote:Yup MLSR gaskets need a good surface. What is the head like in that spot?
Time for CA18DET perhaps?
92mr2paddy wrote:this might be a stupid and unrelated question but how come your pistons have 4 recesses for valves but the head only has 2 valves??
QikStarlie wrote:looks like detonation, caused both the melted plugs and the bhg. likely too much ignition advance and the plug would be a hot spot.
touge_ae101 wrote:Throw it away. Start again. Need more valves. Start with 20 that should do it fine.
my 2c
Dell'Orto wrote:Probably the tune. Any idea of intake air temps at the time?
Stu- wrote:Don't you have water meth setup?
I'm wondering if its stopped for some reason causing fun times inside the engine?
