Black Top VVT Pulley
Postby White Shadow » Thu Apr 03, 2014 10:47 am
Ok so I splashed out and got a brand new genuine VVT pulley :D
Question is I have noticed some engraving on the front of it and what I would call minor pitting on the inside of it....
Is this normal for a new unit?
Can post pictures if that would help.
Also noticed some dirt/marks from what looks like where it has been bolted to a cam shaft?
White Shadow
Re: Black Top VVT Pulley
Postby Kiwi-Corolla » Thu Apr 03, 2014 11:45 am
Definitely post up pics. I replaced mine with a brand new one the other month and while I didn't examine it closely, I definitely didn't notice anything like that. Where'd you buy it from?
Kiwi-Corolla
Postby White Shadow » Thu Apr 03, 2014 12:22 pm
White Shadow
Postby Kiwi-Corolla » Thu Apr 03, 2014 2:27 pm
Hmm, it certainly doesn't look like the most perfectly made pulley out there but it doesn't look bad either.
I can't look at my new one since all of the timing covers are on, but I just had a look at my old one and it has those same lines on the outside edge, albeit a little prettier.
Did you buy the pulley from a Toyota dealership?
Kiwi-Corolla
Postby Grrrrrrr! » Thu Apr 03, 2014 2:54 pm
The "pitting" looks like a section where the casting hasn't been machined, and is nothing to worry about IMO.
I'm guessing those two lines are where they have checked the VVT travel, should be about 15degrees apart.
Grrrrrrr!
Postby White Shadow » Thu Apr 03, 2014 3:56 pm
Wicked thanks for your help :D
All the parts I deal with at work are perfect condition IE no marks like these and also after spending so much money on it I kinda want to make sure
Now just waiting for the genuine cambelt kit to come in :D
White Shadow
Postby Mr Revhead » Thu Apr 03, 2014 11:14 pm
Normal casting marks etc for a maker that has to count every penny ;)
No point machining a surface if it doesn't need it
Postby Bazda » Fri Apr 04, 2014 9:39 am
That looks 100% normal.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 9 guests
