Trailer lights...
Trailer lights...
Postby Mr Revhead » Thu Apr 10, 2014 7:18 pm
So I've had 4 different trailers plugged into the 4wd.
The brake lights won't work with any of them, have been both bulb and LED type.
The wiring on the 4wd checks out according to Narvas wiring diagram, and using a test light there is power and a good earth.
I'm stumped.
Re: Trailer lights...
Postby Lloyd » Thu Apr 10, 2014 7:52 pm
4 dodgy trailers?
Check the pins for power when it's actually plugged in too. You may find it has a bad connection that's letting enough voltage through to power a test light but not the brake lights.
Postby Mr Revhead » Thu Apr 10, 2014 7:54 pm
What are the odds?!
I guess the only thing I can do is put a multi meter on it and make sure there's decent current there?
Postby wde_bdy » Thu Apr 10, 2014 10:00 pm
As above, probably a poor connection on the pins. If it is just the brake lights not working wrap a little tin foil around that pin and test it again. Spent hours chasing an issue like this in the past with a borrowed trailer, earth pin was a bit squashed and not connecting when plugged in.
Callum
wde_bdy
Postby gepsk8 » Fri Apr 11, 2014 1:04 am
Plug in a trailer, take cover off see if getting signal throughs the plug.
Normal if 7pin flat just light spread pins little. Normal most of problems
O272754663
gepsk8
Postby Crucible » Fri Apr 11, 2014 8:42 pm
Do you have power on the trailer connector side or were you testing unplugged on car connector. Sounds like brake + pin connection to me also.
Crucible
Real Life Mechanic
Postby 85AW20v » Fri Apr 11, 2014 8:56 pm
Replace one of the trailer plugs with one from Supercheap that has the LED tester built in. About $16 at the moment.
See ya
Simon
85 MR2 20v
85AW20v
Postby wde_bdy » Fri Apr 11, 2014 9:58 pm
85AW20v wrote:Replace one of the trailer plugs with one from Supercheap that has the LED tester built in. About $16 at the moment.
Which will then fail in 5 minutes. Been there, done that.
Callum
wde_bdy
Postby KinLoud » Sat Apr 12, 2014 12:58 pm
Callum
Same - good idea but very badly made
Postby Mr Revhead » Sat Apr 12, 2014 1:20 pm
Yeah can't really do that with a bunnings/gas station/hire trailer though!
Have a new plug and will take a look this arvo
