Black Top 20v Spark plugs?
Postby White Shadow » Fri Apr 11, 2014 12:19 am
Hey all
Rang Appco today and got a part number for spark plugs for my car.
Some how I don't think they are right...
Thoughts?
http://www.boschautoparts.com/VehiclePa ... t_num=4418
PS New VVT pulley is on! :D
White Shadow
Re: Black Top 20v Spark plugs?
Postby Lloyd » Fri Apr 11, 2014 1:16 am
Use NGK or Denso, steer clear of Bosch for most Japanese stuff.
BKR6EP-11 (I think)
Call Toyota though, they're often better priced on plugs than Repco/BNT/Appco anyway.
Postby Boosted_162 » Fri Apr 11, 2014 8:20 am
Lloyd wrote:Use NGK or Denso, steer clear of Bosch for most Japanese stuff.
Out of interest, why do you say this? I used them in my RB26DETT. Only problem i found was the ceramic broke on one, but I think thats because my mate dropped it... :lol:
Postby Lloyd » Fri Apr 11, 2014 9:53 am
They just don't always seem to play nice together. I don't know any reason for it, that's just in my experience. It goes both ways though. I'd rather be putting genuine plugs in a Falcon (for example) than NGKs.
This is very generally speaking and I'm sure there are millions of happy people with Japanese cars and Bosch plugs driving around :)
Postby Dell'Orto » Fri Apr 11, 2014 7:28 pm
Odd they'd give you a Bosch plug number when they don't sell them....
Postby White Shadow » Fri Apr 11, 2014 7:31 pm
Sweet will give toyota a ring next week
Yea they gave me a few part numbers that cross referenced
White Shadow
Postby matt dunn » Fri Apr 11, 2014 9:30 pm
I wouldn't run bosch either, and we were a bosch dealer.
the problem with bosch spark plugs is the range is not wide enough,
There are about 50 different NGK spark plugs that will all cross over to 1 single Bosch plug.
For a blacktop 20V
From NGK site
Recommended Plug BKR6EP-11
Iridium option BKR6EIX-11
Postby TRD_ZERO » Mon Apr 14, 2014 9:53 pm
They are about $5.50 each from BNT
Previous:
TRD_ZERO
Postby White Shadow » Tue Apr 15, 2014 6:26 pm
TRD_ZERO wrote:They are about $5.50 each from BNT
Yea I have some of those in the car now and it runs like a bag of shit :cry:
Will try Toyota plugs next
White Shadow
Postby Mr Revhead » Tue Apr 15, 2014 7:33 pm
Toyota do Denso and are pretty cheap.
Postby 1I1 » Tue Apr 15, 2014 7:47 pm
As above Denso plugs are pretty cheap.
Can do a set of Platinum plugs (factory fit) for $78.75 delivered or standard plugs for $16 delivered.
TRD Clicky >>Here
1I1
Postby TRD_ZERO » Wed Apr 16, 2014 11:16 am
Intereting
I haven't had any problems running them on my turbo black top.
Previous:
TRD_ZERO
Postby JZCrazy » Wed Apr 16, 2014 6:07 pm
Probably need to regap the bkr6ep11 plugs if they are in a turbo motor?
JZCrazy
Postby Lloyd » Wed Apr 16, 2014 6:10 pm
Or just buy BKR6EP-8 plugs instead.
Postby Kiwi-Corolla » Wed Apr 16, 2014 6:15 pm
I get my spark plugs from this guy, only $11 each:
Denso Platinum PK20TT - http://www.trademe.co.nz/motors/car-par ... 724485.htm
or
NGK Platinum BKR6EGP - http://www.trademe.co.nz/motors/car-par ... 204464.htm
Both have a gap of 1.1mm, which is perfect for the 20v.
Kiwi-Corolla
Postby allencr » Thu Apr 17, 2014 11:32 am
Good.
Now take them out and look at them, after reading what you can from stuff like
http://www.strappe.com/plugs.html
http://www.dragstuff.com/techarticles/r ... plugs.html
http://www.4secondsflat.com/Spark_plug_reading.html
http://www.dansmc.com/Spark_Plugs/Spark ... talog.html
You may even find out it's not a plug problem.
quit asking others what they can only guess at or following the factory recommend stuff for a new unmodified average conditions engine.
Also, the very last place in the entire world to get plugs from is the Toyota(or any other) Dealer!
allencr
Postby rollaholic » Thu Apr 17, 2014 6:35 pm
was it running like shit before you replaced the vvt pulley?
