Postby NILPSI » Tue May 06, 2014 2:48 pm
I have some, even got them painted at the same time that I did the car!
Just undecided if I should put them on... I really like how it looks now, nice and simple
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby Mr Ree » Tue May 06, 2014 6:27 pm
Doooo eeeeeet ;)
On the weekend, I flushed and bled the brake fluid with motul rbf600, and I also changed the oil, so I undid the oil cooler lines so I could get as much of the old stuff out as possible, given that the cooler, lines, for the filter relocation added about 3/4 of a litre of oil to the system, which means that without doing the above, an oil change of more of an oil dilution, than a full change haha.
Also removed, cleaned, and refitted the coupler that goes from my compressor cover to the piping as it kept blowing off the last time I was at Manfeild, due to a little oil spill the day before, creeping inside it and allowing it to slip off under boost. Hopefully thats the last time that happens.
wak thud gush!
Mr Ree
Postby Boosted_162 » Wed May 07, 2014 8:05 pm
Got my baby back today with a lovely new rear end :lol: finally got my Cusco LSD installed.
Also got my Impul rear wing at GT Refinishers getting painted, hopefully fitting this friday :D
Postby 1I1 » Sat May 10, 2014 5:01 pm
Flushed out oil cooler then moved on to removing old sealant from the windage tray. Used Wurth Sealant Remover. Worked a treat! Managed to get a tiny bit on a cut on a finger... provided a nice pleasant stinging feeling lol.
Bigend shells out tomorrow!
TRD Clicky >>Here
1I1
Postby Grrrrrrr! » Sat May 10, 2014 6:16 pm
Lapped the valves in the head, and checked them with bearing blue. Didn't wear gloves and went a bit overboard with the bearing blue, so it looked like i'd been lurking in alley ways giving smurfs $20 handjobs..
Grrrrrrr!
Postby Bling » Sat May 10, 2014 8:55 pm
Dusted off the AE70.
That's all...
Postby disturbedphil » Sat May 10, 2014 9:11 pm
Grrrrrrr! wrote:so it looked like i'd been lurking in alley ways giving smurfs $20 handjobs..
possible new signature quote??
disturbedphil
Postby Dell'Orto » Sat May 10, 2014 9:18 pm
I cleaned around my sedan, in preparation of moving somewhere
Postby Boosted_162 » Sat May 10, 2014 9:48 pm
I gave a friend a lesson on the life of cars. First I tried to leave a carpark and shamefully got beached :oops: Had to get a lift off! Then I tried to flatten a speed hump after I didn't see it till the last minute.
I'm sure she thinks i'm mad driving a car like that :lol:
Postby matt dunn » Sun May 11, 2014 12:48 am
Boosted_162 wrote:I gave a friend a lesson on the life of cars. First I tried to leave a carpark and shamefully got beached :oops: Had to get a lift off! Then I tried to flatten a speed hump after I didn't see it till the last minute.
So all in all, a good first date then?
Postby Boosted_162 » Sun May 11, 2014 11:13 am
Guess it all depends on how much they like unpractical things :lol:
Postby CAMB01 » Sun May 11, 2014 1:14 pm
Looked at it, bolted a rear hub, disc and wheel on, Swore and laughed at the same time, then looked at it some more while thinking about things I need to do to it.
Oh also cleaned and painted the front subframe.
Made a list of Parts I need.
Because racecar!
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Leon » Sun May 11, 2014 5:27 pm
Raced the Honda.
Didn't crash.
Drove home again.
Good day
Postby iOnic » Mon May 19, 2014 11:38 am
Yesterday/day before visited the smash repair place. Can't even tell it's had a truck to the side.
Today filled up the rental Veloster with E10. Doesn't drive any different but $48 from fuel light makes me happy.
Postby Stott69 » Mon May 19, 2014 11:51 am
Mums got one of those Hyundais, reacons it goes rather well
Stott69
Postby iOnic » Mon May 19, 2014 1:11 pm
Yeah seems to go ok. Not quick but nice to drive
Postby Kiwi-Corolla » Tue May 20, 2014 6:24 pm
Polished and waxed it:
Kiwi-Corolla
Postby loudstealthGT-Four » Sat May 24, 2014 10:57 pm
Spent last couple of weekends getting my car to look like this
Then watched/helped prime it this afternoon.
Already for a big day/days of blocking.......
Also had a friend offer me this for $550
NZ New Widebody ST185 :D
loudstealthGT-Four
Postby Boosted_162 » Sat May 24, 2014 11:09 pm
Nice widebody! Means you get the 260k speedo too :P Loving the wheels on your black one, at a guess they look like SSR Professors and not Meisters??
Today I put some Penrite LSD additive in to try and shut the Cusco LSD up a bit. Is an improvement but still a noisy thing! May pull it out at some point and change the clutch plates so it's not so aggressive.
Postby loudstealthGT-Four » Sat May 24, 2014 11:29 pm
Boosted_162 wrote:Nice widebody! Means you get the 260k speedo too :P Loving the wheels on your black one, at a guess they look like SSR Professors and not Meisters??
Yip was stoked when I seen that! Wheels are SSR SP1's, would love a set of Miesters though...
Might tidy up the black one will all the good bits on the red one, then use the red one for racing???
loudstealthGT-Four
