AE82 FXGT sounds like a diesel
Postby 1984FXGT » Fri May 09, 2014 9:34 am
Help my AE82 Fxgt sounds likes a 1980s diesel at idle. Has a loud ticking noise comming from the head. Any ideas what it can be? It has only started in the last few weeks and am a little concerned about that it can be. The engine still goes fine and still hits redline with no issues but when idleing it sounds like a diesel tractor.
Engine is a 4age silvertop.
Thanks
1984FXGT
Re: AE82 FXGT sounds like a diesel
Postby Dell'Orto » Fri May 09, 2014 11:04 am
Do a search on VVT pulley ;-)
Postby 1984FXGT » Fri May 09, 2014 11:06 am
Does that effect the performance of the vvt at all?
1984FXGT
Postby Mr Revhead » Fri May 09, 2014 5:12 pm
No, but it interferes with the flux capacitor.
:P
Yes it does, it controls the VVT.
Check the FAQ
Postby RS13 » Sat May 10, 2014 1:05 am
Take the plug off the VVT solenoid and apply 12V to it at idle. The noise should stop with power applied.
RS13
Postby 85AW20v » Sat May 10, 2014 9:10 am
RS13 wrote:Take the plug off the VVT solenoid and apply 12V to it at idle. The noise should stop with power applied.
Although that will drop the revs a bit and make it sound like it's got a lumpy cam in it - if you're old enough to know what that sounds like!! :wink:
See ya
Simon
85 MR2 20v
85AW20v
