Hiace starts lazy/funny?
Postby 92mr2paddy » Sat May 17, 2014 7:29 pm
ok so ive had my hiace for around 2 years now and its always started a lil strange, it will turn over once realll slow then turns over one more time quick and boom its idling, has started everytime since ive had it but last night it did like 5 slow as hell turn overs then just clicking,, (same sound as a flat battery), did it again and it did its normal one slow then normal and started just fine, has done it a few time since then during driving today, battery obviously not flat as it starts eventualy.
possibly starter motor?
bad connection? > where? by ignition or by starter?
cheers pat
92mr2paddy
Re: Hiace starts lazy/funny?
Postby gepsk8 » Sat May 17, 2014 10:33 pm
All issue could be, start with battery get it tested, battery shop or auto sparky will do it for free. they only have life two year rest is bonus, battery termals clean wire attached. Earth cables attached clean attached, same with positive attached to starter. If all is ok start sounds like starter, if petrol could be timing too.
O272754663
gepsk8
Postby James Sen » Sun May 18, 2014 11:30 am
A guy at my work have the exact same problem, but only did it for a week before he changed his battery and it didn't happen again.
1992 MR2 GTS 353kw@ the wheels on 23psi(pump gas) 11.3@206km/h
1998 Toyota Carina with a GTT caldina 3sgte.
1986 AE86, beams engine 6spd gearbox
James Sen
