4afe won't idle
4afe won't idle
Postby KinLoud » Wed May 14, 2014 3:33 pm
Before I pull stuff apart to start fixing I though I'd ask for the top 3 reasons why it won't idle
It was ok driving home last night.
Moved car out of carport this morning (about 15 seconds engine running)
Was heading off to town about 1 hour later - won't idle.
Drives fine but will die as soon as I let it idle
Thanks
Ken
Re: 4afe won't idle
Postby RS13 » Wed May 14, 2014 6:40 pm
Vacuum leak, jammed IACV or something random like timing spring to mind. Is it doing it hot, cold or both? Any codes?
RS13
Re: 4afe won't idle
Postby KinLoud » Wed May 14, 2014 11:14 pm
RS13 wrote:Vacuum leak, jammed IACV or something random like timing spring to mind. Is it doing it hot, cold or both? Any codes?
Thanks
Problem only started this morning
Cold and 1/2 warmed up (drove it about 3 km to see if prob would disappear)
Will check codes
Power seemed normal (ie timing belt ok)
Replaced cambelt tensioner etc about 10,000km ago
Will keep everyone updated
Re: 4afe won't idle
Postby gepsk8 » Wed May 14, 2014 11:19 pm
How many k's wax idle units do crap out.
Clean out throttle body idle bypass ports.
Needs tune up?
O272754663
gepsk8
Re: 4afe won't idle
Postby TOYWGN » Sat May 17, 2014 12:32 am
Maybe auto choke needs a clean? Or throttle body clean?
1997 Jzx100 Tourer v !!!!
TOYWGN
Re: 4afe won't idle
Postby sergei » Mon May 19, 2014 11:51 am
TOYWGN wrote:Maybe auto choke needs a clean? Or throttle body clean?
There is no choke on 4AFE ;).
Most likely stuck idle control valve. Should be attached to the bottom of the throttle body, gray/tan "box" with 3 wire plug. To attempt to clean it soak it in carb cleaner by spraying into the hole (about 6-8mm) in front of the throttle body.
The hole is visible on this pic (as well as the valve body itself):
There is another hole on the top (inside of the throttle body mouth), it is for idle screw adjustment (if you have it), you could also attempt cleaning that, but generally it only should be used to adjust idle on hot.
Re: 4afe won't idle
Postby KinLoud » Wed May 28, 2014 10:33 pm
Finally updating this thread,
Yep - cleaner down the idle air valve hole did the trick
Took a bit of fiddling around i.e. spray cleaner, start engine with some throttle (because it won't idle),
about 2000rpm then close throttle to make it suck through idle valve,
engine stops, repeat until it idles
Thanks for everyone's input
Ken
Re: 4afe won't idle
Postby allencr » Sat May 31, 2014 7:43 am
KinLoud wrote:Yep - cleaner down the idle air valve hole did the trick
Thanks for reply with the fix.
If this doesn't F'itUP, nothing will.
allencr
