Map ecu 3
Map ecu 3
Postby TOYWGN » Thu Jun 05, 2014 11:09 pm
Hi there just wanting to know if anyone on here has had Map Ecu 3 as I'm looking at putting it on my jzx100 chaser.
I think FLAWLES may have had one?
Any help would be the coolies!
Cheers Jason.
1997 Jzx100 Tourer v !!!!
TOYWGN
Re: Map ecu 3
Postby 7ishNZ » Sat Jun 07, 2014 5:55 pm
Had one one my 3sgte lotus 7. Worked OK, but the software was very flakey. That was 2 years ago, hopefully they have improved it. It used to be really hard to load a new map into it, sometimes it would load, other times it would be blank.
The USB interface was crap.
Once it was tuned, as long as you didn't fiddle with it, it was good.
7ish
7ishNZ
Re: Map ecu 3
Postby steroidcontaskie » Sun Jun 08, 2014 12:03 pm
I have one in the my 2jzge turbo. Are you installing it yourself? Is the car an auto?
USB connection is slow to update tables.
Install is easy, a mate helped me do it.
Support was really good.
Easy to use, but is limited functionality
Because it is a piggy back you can use it with an auto. Most full after markets are a problem with an auto.
What do you want to control with it?
Edward
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
Re: Map ecu 3
Postby TOYWGN » Tue Jun 10, 2014 11:20 pm
steroidcontaskie wrote:I have one in the my 2jzge turbo. Are you installing it yourself? Is the car an auto?
Edward
Hi there will be putting it into Jzx100 auto chaser
Also who did the tuning for you?
TOYWGN
Re: Map ecu 3
Postby TOYWGN » Tue Jun 10, 2014 11:25 pm
Edward
Not really after massive power as i have had the turbo rebuilt with CT26 core (Steve Murch) so i think this will be a great option for bang for buck as it would be a problem with full stand alone ecu with auto. :D :D
Cheers Jason.
TOYWGN
Re: Map ecu 3
Postby steroidcontaskie » Fri Jun 13, 2014 12:11 pm
ST Hitec did the tuning, but only up to about 4KPM as the auto let get around then (still havent got it retuned, decided to redo injectors...etc). They have tuned a few MAPECUs, but don't do it alot. If you have a laptop I would get the tuning software loaded on that and make sure you can connect etc, as USB driver can be and issue and you dont want to waste there time.
Unless there is a plug in aftermatket made for you cars ECU like a F-Con V Pro. Then a MAPECU might be as good as it gets for running an auto.
If you like I could pop over sometime and show you my car running with the MAPECU3.
Edward
RVR Turbo (idle)
steroidcontaskie
Re: Map ecu 3
Postby TOYWGN » Sun Jun 15, 2014 1:20 pm
That would be good just to see how it all works. as i know stuff all about it all. :D :D could meet up somewhere if that suits.?
TOYWGN
