Stubborn fuel tank filler hose
Postby Vertigo » Sat Jun 07, 2014 5:45 pm
Im dropping the fuel tank on my adub, and the only thing left to disconnect is the big filler hose. Its being a right bitch - compresses maybe half an inch, with another inch to go before it comes off. The thing is hard as a rock. Any advice on getting it off?
TVIS just kicked in, yo!
Vertigo
Re: Stubborn fuel tank filler hose
Postby Vertigo » Sat Jun 07, 2014 6:39 pm
Ok, managed to get it off by getting frustrated and unbolting the metal pipe that leads to the filler cap, and jiggling that around instead. Whatever works!
Vertigo
Postby Dell'Orto » Sat Jun 07, 2014 7:13 pm
Was going to suggest brake cleaner, Its quite good for softening hoses to make em easier to pull off
Postby GDII » Sat Jun 07, 2014 8:33 pm
I would suggest dropping the tank with the large rubber hose on. When the tank drops out the pipe comes off. Well that's how an SW20 works. Makes getting the pipe back onto the rubber hose easier when you put it back in.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
