ZZE122 Fielder Remote Central Locking Install
Postby Alex B » Sun Jun 08, 2014 7:23 pm
I have a remote central lock kit I'm trying to install in my Fielder. It has factory central locking, but the only key I got given is just a plane old key, no smarts. When you press the door lock button you can hear a click from a box above the glovebox called Relay Integration, if I unplug said box then central locking stops working. So guessing I need to tap the lock/unlock signals to this box.
On the off chance does anyone know the colours I'm after for this?
Are Toyota's usually neg trigger for both lock/unlock?
Where is the best place to tap the indicators? It looks like they may run down the passengers side loom. The remote central lock kit has 2 outputs so that makes life a bit easier.
Years ago I used to love messing around with this stuff, but the car is new enough if you mess it up it may break stuff, and working outside in Dunedin winters suck.
Cheers for any help.
Re: ZZE122 Fielder Remote Central Locking Install
Postby matt dunn » Sun Jun 08, 2014 9:04 pm
I fitted keyless entry to mine with an aftermarket kit,
as we have a smartlock remote, but only one.
Easiest place to tap into the lock/unlock
is where the wires go through the door to the lock/unlock button on the drivers window control panel.
Indicators I don't remember but I usually try at the connector to the indicator switch first.
I dont remember it being tricky at all like altezza wagons are etc.
Postby XS1V » Mon Jun 09, 2014 10:18 pm
ST205 Group A Rallye #2363
XS1V
