Lith wrote:Hmm - forgive me if I am missing something, or if I am a rough guy (not to mention not actually answering your question haha).... but if you have a Link+ (I've not played with these old relics before so could be making an incorrect assumption) shouldn't you be able to upgrade to a 3bar MAP sensor? And if so, wouldn't that probably be cheaper, easier and also give you more headroom to make for more happy fun times in future than spending the money and time installing and tuning a new boost controller?
Just a thought Alternatively, if you have an external wastegate sometimes changing to spring(s) closer to your target pressure is an effective way of stabilising boost control.
BlakeNZ wrote:http://www.trademe.co.nz/motors/car-par ... 163365.htm
The 3 bar sensor would work fine. You would need to calibrate the sensor in PCLink, but a re-tune would not be required except for the higher boost areas where you are currently not tuned.
On the g1 a retune would be required as the row steps change when switching map sensors. A G4 would allow the swap with no need for a retune.
Lith wrote:Gizzmo do a boost controller which is boost per gear as well, though I suspect it is worth upgrading MAP sensor regardless
~SlideWays~ wrote:Bah... spoke too soon.
http://www.linkecu.com/forums/LinkG1For ... #500718784On the g1 a retune would be required as the row steps change when switching map sensors. A G4 would allow the swap with no need for a retune.
Lith wrote:Crap, I was told Gizzmo did boost by gear but just checked and its only by rpm....weird decision to just do rpm, but you are quite right.
Cruz of it is its clearly time to upgrade to a G4 haha
