Turbo angle
Turbo angle
Postby FST4RD » Sat May 31, 2014 3:35 pm
What is the maximum you would want to tip a turbo up at the front with out having oil issues or any other issues for that matter? Would 45 degrees be too much?
I did see a turbo mounted 90 degrees pointing straight up once, but I assume they had done something to combat the potential oil issues.
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Re: Turbo angle
Postby siren676 » Sat May 31, 2014 5:49 pm
Usually you'll have to rotate the core of the turbo so the oil drain is around 0-15° from vertical so that it can freely flow down to the sump
siren676
Re: Turbo angle
Postby RS13 » Sat May 31, 2014 5:52 pm
Some turbos (aircraft turbochargers, Subaru WRC cars I think as well) are designed with their own oil reservoir so that they can be mounted with the shaft vertical. However, I believe the rule of thumb with 99% of automotive turbos is that the oil drain needs to be within 35° of vertical, otherwise you run into flow (lubrication and heat) and internal leakage issues. What did you have in mind?
RS13
Re: Turbo angle
Postby FST4RD » Sat May 31, 2014 6:05 pm
In the Starion the turbo sits quite a bit forward of the firewall, and the firewall has a decent recess in it.
I was thinking I could make up an adapter to tilt the turbo up at the front which would allow me to run a straight pipe off the back of the turbo. Then once its under the floor pan, a 45 degree bend toward the back of the car. Then I could do away with the downpipe all together.
Cars going to be a track car, so kinda want things as simple and straight forward as possible.
I might even be able to get away with slightly less angle.
FST4RD
Re: Turbo angle
Postby RS13 » Sat May 31, 2014 6:44 pm
Cool idea. Could you mount the turbo lower to reduce the angle? Would you run a flexi? You'd probably be best asking a turbo specialist for clarification.
RS13
Re: Turbo angle
Postby FST4RD » Sat May 31, 2014 7:55 pm
RS13 wrote:Cool idea. Could you mount the turbo lower to reduce the angle? Would you run a flexi? You'd probably be best asking a turbo specialist for clarification.
Yeah I would run a flexi, and I could get a low mount manifold, never thought about that.
FST4RD
Re: Turbo angle
Postby Akane » Sat May 31, 2014 11:59 pm
Garrett recommends 20degree on each side being the maximum allowed.
http://www.turbobygarrett.com/turbobyga ... ooling.pdf
Re: Turbo angle
Postby evil_si » Sun Jun 01, 2014 9:13 am
Akane that particular link is referring to optimium setup of watercooling lines. And is talking about 20' core rotation on the water outlet side,
Garrett had another write up on oil feed and drain angles which i cant find
evil_si
Re: Turbo angle
Postby Akane » Sun Jun 01, 2014 11:00 am
I can't find it neither :(
I do recall it's either 15 degrees +/- or 20...
Re: Turbo angle
Postby DexGT » Sun Jun 01, 2014 11:26 am
I'm also pretty sure it's 15 deg as I remember reading it on the install sheet on my GTX turbo.
The exhaust seal is just a labyrinth type so if you tip the turbo far enough you will submerge it and have a very smokey car.
It sounds like it would be easier to just put a 45 bend off the turbo ,than making the adapter to tilt the turbo .
DexGT
Re: Turbo angle
Postby FST4RD » Sun Jun 01, 2014 12:03 pm
Cool. It was just an idea, I was looking in the engine bay and thought about it.
Plus if possible it would be the least restrictive exhaust as well.
I could probably run a 45 from the turbo with another 45 under the floor, a few mufflers or what have you and the I want it to exit just in front of the rear wheel.
From what I've read and talked to wof guys, as long as the exhaust exits behind the most rear seat it's fine, being the car only has the front seats this will be good. Plus then I don't have to worry about going up and over things at the back of the car.
FST4RD
Re: Turbo angle
Postby GDII » Sun Jun 01, 2014 2:32 pm
Do you mean door rather than seat? Either way you can do that with your car but some cars are 4 door and even if it only has 2 front seats the back of the rear doors are above the rear wheels. That means the exhaust would have to exit behind the wheels.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Re: Turbo angle
Postby Stott69 » Sun Jun 01, 2014 3:09 pm
Weld rear doors, problem fixed?
Stott69
Re: Turbo angle
Postby FST4RD » Sun Jun 01, 2014 4:36 pm
It's 2 door and 2 seat, and there is a decent gap back to the wheels, so either way I should be fine.
FST4RD
Re: Turbo angle
Postby cat007 » Tue Jul 01, 2014 1:32 pm
Put it any angle you like - just use of these:
http://www.ebay.com/itm/NEW-Electric-Oi ... 0782665954
Re: Turbo angle
Postby FST4RD » Tue Jul 01, 2014 11:36 pm
Seems to good to be true... so you could just run a feed from the sump as well as a return and then run your turbo with the intake pointing straight up. That way you could face the exit of the intake housing straight at the intercooler removing the need for a 90° bend...
FST4RD
Re: Turbo angle
Postby Bling » Sat Jul 05, 2014 6:19 pm
Less chance a 90° bend is going to fail on you down the track though :P
Users browsing this forum: Bing [Bot] and 30 guests
