Knock knock - who's there?
Postby cat007 » Sat Jul 19, 2014 10:53 pm
Run a bearing of some sort in the supra the other night. Sounds awful.
Pretty annoying but now it means I can pull the engine and do various things to it I've been wanting to do for a while.
Problem I have is, finding bearings for the 1G-GTE is proving to be rather difficult.
Does anyone on here have any suggestions, that isn't Toyota or Segedins?
Hunt
Re: Knock knock - who's there?
Postby Mr Ree » Sat Jul 19, 2014 11:33 pm
Would you consider a 1J/2J swap, or definitely going to stick with the 1G?
wak thud gush!
Mr Ree
Postby cat007 » Sun Jul 20, 2014 11:05 am
Mr Ree wrote:Would you consider a 1J/2J swap, or definitely going to stick with the 1G?
If anything I would do a 2j. But there's no realistic way I can afford the engine alone, let alone a new gearbox and everything that goes with it....
Postby Mr Ree » Sun Jul 20, 2014 12:48 pm
Yeah, I hear you. The 2J has almost double in price in just a few years :(
Thank god theyre so reliable, as I would hate to have to source a new one.
wak thud gush!
Mr Ree
Postby wde_bdy » Sun Jul 20, 2014 5:02 pm
I'm sure Matt with the 1G Starlet had issues tracking parts down for his, he is on the Oldschool forum so could be worth a chat.
http://oldschool.co.nz/2011/forum/index ... 7-mjrstar/
Callum
wde_bdy
Postby cat007 » Sun Jul 20, 2014 6:41 pm
Thanks Callum - I'll hit up Matt!
Here's a wee vid of the knock. Pretty bad!
https://www.youtube.com/watch?v=zuUxrEo ... e=youtu.be
Postby Dell'Orto » Sun Jul 20, 2014 7:30 pm
Weren't big ends the same/very similar to 4K?
Postby Vertigo » Sun Jul 20, 2014 7:55 pm
I was under the impression that the 1G was very similar to the 4A. Correct me if Im wrong, someone.
TVIS just kicked in, yo!
Vertigo
Postby Dell'Orto » Sun Jul 20, 2014 10:39 pm
Could be 4A, has been ages since I looked into it
Postby thegreatestben » Sun Jul 20, 2014 10:40 pm
I think the K series similarity was the piston rings?
thegreatestben
Postby Mr Revhead » Sun Jul 27, 2014 8:23 pm
Definitely something the same between the K and G, rods? pistons? One version could be used, I recall looking into it when at Toyota but $&#$% if I remember what it was
Postby crispy'86 » Thu Jul 31, 2014 11:45 pm
Try Sedgedins truck and auto http://www.staparts.co.nz/ might be worth a look/try
crispy'86
