4AGE turbo ignition
4AGE turbo ignition
Postby Vertigo » Mon Jul 21, 2014 3:16 pm
My hunch is that Id need to get some hotter plugs. What about 4AGZE plugs, would they do?
TVIS just kicked in, yo!
Vertigo
Re: What spark plugs? 4AGE turbo
Postby Vertigo » Mon Jul 21, 2014 3:31 pm
Sorry, after reading, seems Id need colder plugs, with smaller gap.
Vertigo
Postby whynot » Mon Jul 21, 2014 4:43 pm
I'm still running the factory plugs for my 20v turbo. We just gapped them down to something around .8mm and it's running fine
whynot
Postby Stu- » Mon Jul 21, 2014 6:33 pm
BKR7E
Project Thread
Stu-
Postby allencr » Tue Jul 22, 2014 8:04 am
"My hunch"?
What's in it now and wadda they look like now and what was the engine doing(symptoms and conditions) before you looked at them?
What's the compression? Don't chase a fuel or timing(ignition and/or cam) problem with iridium spark plugs.
There are an amazing number of sparkplugs for a limited number of conditions, they just have to be hot enough to not load up with carbon/short out/miss when the engine is idling and also cold enough to not melt/chip/crack/break/miss when the engine is under a load/WOT/accelerating, and they have to last a while before replacement or filing/re-gapping.
Also, there is a lot of advertising bullshit about multiple ground electrodes/straps and copper that should be ignored as deceptive advertising at the least, but is really illegal criminal fraud IMO.
http://www.strappe.com/plugs.html
http://www.dragstuff.com/techarticles/r ... plugs.html
http://www.dansmc.com/Spark_Plugs/Spark ... talog.html
http://www.dragstuff.com/techarticles/h ... plugs.html
allencr
Postby Vertigo » Wed Jul 23, 2014 11:21 pm
My hunch means Im thinking about what to use when my turbo build is complete. Suggestions?
Vertigo
Postby headshotnz » Thu Jul 24, 2014 9:35 pm
pk20r8 is what a 3sgte uses standard, maybe a good start?
Find some some one with a trade account and buy your plugs through Toyota, Denso plugs have a max of 30+ retail.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Re: 4AGE turbo ignition
Postby Vertigo » Sat Jul 26, 2014 8:17 pm
Speaking of ignition, thought Id expand my post a bit.
Ive got a pair of GZE coil packs and a CAS. I will be getting an ECU of some kind obviously, either MS, link, or whathaveyou. Ive been told I might need a Mitsi igniter, but is this the case, or can I get away with controlling the coils directly with an ECU? Would make things a bit more simple. What should I do?
Vertigo
Postby Stu- » Sat Jul 26, 2014 10:45 pm
It will depend on the ecu you end up running. For example MS has inbuilt igniters if you go down that route however I prefer Links which require external igniters.
To run wasted spark you will need a dual channel igniter - either a stock Mitsi one or even two single channel igniters as long as they're 'dumb' igniters as the dwell will be controlled by the ecu. I've got a Link dual channel ignitor for sale if you need one. I've had GZE coils in setups in the past and they work fine but I have had a few die. The mitsi ones work well as an alternative and are easy to find. Or what you could do is run 2zzge coil on plugs with inbuilt ignitors and just pair to run as wasted spark if that's all your ecu is capable of running. I've run this in a fair few customers cars with good results (both wasted and individually driven).
You'll also need to consider that if your original tacho ran from a single coil (ie high level drive) you will need to think about how you will drive the tacho from the new setup. If your going for wasted spark, try to find a mitsi tacho interface which is a neat solution that combines the coil- pulses from each coil so your tacho runs normally. You can also make a tacho interface from resistors if you can't find an interface.
If you can, run the tacho direct from the ecu (with Links this works well) but you will need to change the internal resistor inside the tacho to a 1ohm unit (its very easy to do) so that it will run from a low level drive.
Project Thread
Stu-
Users browsing this forum: No registered users and 32 guests
