3S-GE/FE rings = same as 2JZ rings
Postby cat007 » Tue Jul 29, 2014 12:52 pm
So turns out the 3S-GE/FE rings are the same size as 2JZ ones.
The sizes are the same, and as long as I get the set with the chromoly coated top ring, it should be fine?
Re: 3S-GE/FE rings = same as 2JZ rings
Postby RomanV » Sat Aug 09, 2014 7:53 pm
There are different thicknesses even for the 3SGE rings, so it really pays to get the right ones.
Postby cat007 » Sun Aug 10, 2014 1:13 pm
RomanV wrote:There are different thicknesses even for the 3SGE rings, so it really pays to get the right ones.
Ah, yeah that isn't ideal!
STAParts are waiting on a shipment from overseas, so I'll be getting the actual 2J bearings then,
Thanks
Users browsing this forum: No registered users and 34 guests
