Jun flywheel paint?
Jun flywheel paint?
Postby ®usty » Sun Aug 24, 2014 10:08 pm
Just regarding my new Jun flywheel I have. It's painted or anodised black from Jun.
For people who have bought and installed a Jun flywheel, did you have this on your flywheel? Did you remove it from the surface area the clutch disk touches?
®usty
Re: Jun flywheel paint?
Postby CAMB01 » Sun Aug 24, 2014 11:10 pm
Interesting....my JUN flywheel never looked like that.
If it was me i would clean up the clutch disc area as best as possible with brakeclean. I would hazard a guess at that might be a soft sealer to protect against corrosion.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby atmosports » Mon Aug 25, 2014 12:49 pm
I'm more than liking guessing it's either black oxide(black zinc) to protect it from rust/corrosion or it may well be that colour from nitriding depending on he material they use
atmosports
Postby Bazda » Mon Aug 25, 2014 4:56 pm
Im sure its zinc. Just like how many brake disc rotors are done these days to stop rust.
Once you run the clutch the zinc will burn away in the friction area.
Postby ®usty » Mon Aug 25, 2014 5:47 pm
Cool thanks for your help/replys much appreciated.
®usty
Postby ®usty » Mon Aug 25, 2014 10:06 pm
I also flicked an email to Jun, not half expecting a reply but I just got this in the inbox
Thank you for your mail. The black color is for hardness by heat
treatment (nitridization, nitriding). Dont mention it.
Thank you,
Junichi Tanaka
®usty
