C56 gearbox question
Postby sark.inc » Sat Oct 18, 2014 11:50 pm
I just put together a C56, and I went and tested gear selection and now it seems to be jammed into either 1st or 5th section and can't work out why it will not budge back.
Any ideas?
sark.inc
Re: C56 gearbox question
Postby DexGT » Sun Oct 19, 2014 12:45 am
Last time I had that problem I hadn't put the two balls back in the selector arm , only one equals locked in gear
DexGT
Postby sark.inc » Mon Oct 20, 2014 1:24 pm
The only thing i changed was the bell housing due to other one being damaged, not sure how that could of caused the above mentioned... :?
sark.inc
Postby Stu- » Mon Oct 20, 2014 3:11 pm
As above, usually caused by the detents not being fitted. Pretty sure you have to take one out to get the casings appart
Project Thread
Stu-
Postby sark.inc » Mon Oct 20, 2014 4:33 pm
Does anyone have a picture for a reference, i put everything together in my car and as you can understand i do not want to have to do it again so i want to make sure i don't miss anything... :evil:
sark.inc
Postby Stu- » Mon Oct 20, 2014 4:43 pm
They're under the hex screws in the side of the casing so you shouldn't have to take the box out or appart
Project Thread
Stu-
Postby sark.inc » Tue Oct 21, 2014 11:29 am
excellent, ill check to see all that it does have both.
If not, god knows what i shall do.
sark.inc
Postby sark.inc » Wed Nov 19, 2014 7:54 pm
Well that appears not to be the problem...
Does anyone have a rebuild manual?
sark.inc
Postby 85AW20v » Wed Nov 19, 2014 8:54 pm
Are you sure the 3 selector slots were all in line i.e. in neutral when you put the selector arm back in? You'll need to take the selector assembly out to check.
See ya
Simon
85 MR2 20v
85AW20v
Postby sark.inc » Wed Nov 19, 2014 9:12 pm
The selector arm was never removed. :\
sark.inc
Postby Mr Revhead » Thu Nov 20, 2014 11:28 am
You haven't bent the external linkages have you? the might be jamming against each other or not moving the full sweep.
I had that after a clutch change, must have banged them at some point and had gear selection issues
Postby 85AW20v » Thu Nov 20, 2014 9:53 pm
sark.inc wrote:The selector arm was never removed. :\
But the bell housing was and the selector rods for 1st or 5th may have moved when refitting the bell housing as the selector arm would probably have held the centre rod in position as that is the default.
See ya
Simon
85 MR2 20v
85AW20v
Postby sark.inc » Sun Nov 30, 2014 11:18 am
well, found the problem are pulling it apart.
The person who put it together for me left the ball in the slide and it jammed it as such, also ruined the spring.
Does anyone know a good place to get a box rebuilt?
sark.inc
Postby ch4ng » Sun Nov 30, 2014 10:54 pm
Ross @ Auto Power Services
5/58 Lansford Crescent, Avondale, Auckland
09 828 7215
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
