fujitsubo rear muffler, toss or repair - rattles
Postby Shins » Tue Dec 09, 2014 7:44 pm
i was checking my rear muffler for an annoying rattle so unbolted it from car to discover when i shake the muffler it sounds like a metal pipe has come loose inside it
sadly it was a good muffler new it is part of a fujitsubo cat back system, car is ae111 sprinter trueno bzr
so is it worth even bothering to get quotes to repair it or just bite the bullet and replace it, i want another bolt on unit if poss
Shins
Re: fujitsubo rear muffler, toss or repair - rattles
Postby Dell'Orto » Tue Dec 09, 2014 8:26 pm
I doubt it's economically viable to repair. The rattles are from the internal baffles breaking off, so would require basically completely rebuilding.
AdrenalinR may be able to make a suitable bolt on replacement?
Postby Heylin » Thu Dec 11, 2014 1:16 pm
+1 on Adrenalin R stuff. best exhaust \ muffler ive used.
Going by price for these
http://www.trademe.co.nz/motors/car-par ... 612099.htm
Your replacement would be under $300.
Heylin
Heylin
Postby phoenix » Fri Dec 12, 2014 1:41 pm
It seems a lot of the Japanese mufflers like that use mild steel internal pipe, and rust out over time. I've also found quite a few of the 3" systems actually squeeze down to 2.5" or even 2.25" (mild steel) through the muffler.
It would probably only be economic if you were rebuilding it yourself, or you really wanted to keep that muffler exterior. I did it once myself, probably wouldn't do it again.
11 second Honda
phoenix
Postby Shins » Sat Dec 13, 2014 11:33 pm
thanks for replies will probably commit to a new cat-back in the long term, but after christmas D:
Shins
Postby Vertigo » Sun Dec 14, 2014 5:54 am
Ive got a similar muffler just sitting around that I could never use. $50? Youd need to weld that bend piece on.
TVIS just kicked in, yo!
Vertigo
