whynot wrote:I'm kinda hoping it's not the turbo as I don't want the hassle of reworking things for a new turbo unless there is a bolt on upgrade in which case I'm all ears.
If the turbo is at its limit wouldn't that mean the boost would drop off even if you try to run a higher setpoint? It had no problems running higher boost.it just makes no difference to the peak power. 17psi or 21psi makes the same power
whynot wrote:I have been reading up on the turbo specs and what I have is not a standard Evo 3 td05. It looks to be some bored out unit with larger compressor and exhaust wheels. Not hugely different but definitely not standard, well according to what I can find anyway.
I will keep working on it and let you guys know the outcome.
Dell'Orto wrote:Probably a bit of hassle to swap turbo flanges now, but ATA|'s setup made the power you're after with relative ease
viewtopic.php?f=29&t=81064
Lith wrote:whynot wrote:I have been reading up on the turbo specs and what I have is not a standard Evo 3 td05. It looks to be some bored out unit with larger compressor and exhaust wheels. Not hugely different but definitely not standard, well according to what I can find anyway.
What details do you have about it? Have you got wheel sizes or anything? If it's in the stock turbine housing then it could still be the hold back possibly - though I still wonder if there is any engine tuning issues (either physically or in the ECU) which could be addressed from our convo a couple of weeks ago, did you try anything I mentioned?
Also someone I know is on the hunt for an early model EVO turbo....Dell'Orto wrote:Probably a bit of hassle to swap turbo flanges now, but ATA|'s setup made the power you're after with relative ease
Funny thing about that is that a 16G6 compressor can technically flow the same or more than a GT2860R if it's not held back by anything!
