Orange Canister next to fuel filter AE101
Post Reply
z0ton
Post by z0ton »
What is this little canister for and is it required?
Re: Orange Canister next to fuel filter AE101
Post by sergei »
z0ton wrote:What is this little canister for and is it required?
There was a question from other member regarding fuel smell... , it looks like you have NZ new car (as far as I know they didn't come with many emission control items) and this is a fuel tank breather.
Here is the post:
viewtopic.php?f=3&t=93494
z0ton
Post by z0ton »
Here is the post:
Yea it is NZ new, no issues it was more out of curiosity than anything. I thought that's what it might be thanks.
MrOizo
Toyspeed Legend
Contact:
Post by MrOizo »
So how does this work?
Does it terminate at the canister or plumb elsewhere?
I wouldn't mind changing my setup to something newer and more compact.
Thanks!.
Post by sergei »
MrOizo wrote:So how does this work?
Thanks!.
It simply vents it into atmosphere, unlike the charcoal canister absorbing the vapour and then releasing when the engine is running into intake.
Stu-
Post by Stu- »
Quite often they vent into the chassis leg
Project Thread
Post by sergei »
Stu- wrote:Quite often they vent into the chassis leg
That's right! they go in the hole in the chassis rail.
On side note the NZ New cars that lack oxygen sensor also have an adjuster near left strut tower (black pot with 3 or 4 wires coming of it).
I assume that is the mixture adjuster.
Post Reply
