Orange Canister next to fuel filter AE101
Postby z0ton » Sun May 17, 2015 10:12 pm
What is this little canister for and is it required?
z0ton
Re: Orange Canister next to fuel filter AE101
Postby sergei » Mon May 18, 2015 9:44 am
z0ton wrote:What is this little canister for and is it required?
There was a question from other member regarding fuel smell... , it looks like you have NZ new car (as far as I know they didn't come with many emission control items) and this is a fuel tank breather.
Here is the post:
viewtopic.php?f=3&t=93494
Postby z0ton » Mon May 18, 2015 1:20 pm
Here is the post:
Yea it is NZ new, no issues it was more out of curiosity than anything. I thought that's what it might be thanks.
z0ton
Postby MrOizo » Mon May 25, 2015 10:09 pm
So how does this work?
Does it terminate at the canister or plumb elsewhere?
I wouldn't mind changing my setup to something newer and more compact.
Thanks!.
MrOizo
Toyspeed Legend
Postby sergei » Mon May 25, 2015 11:17 pm
MrOizo wrote:So how does this work?
Thanks!.
It simply vents it into atmosphere, unlike the charcoal canister absorbing the vapour and then releasing when the engine is running into intake.
Postby Stu- » Wed May 27, 2015 6:51 pm
Quite often they vent into the chassis leg
Project Thread
Stu-
Postby sergei » Fri May 29, 2015 4:17 pm
Stu- wrote:Quite often they vent into the chassis leg
That's right! they go in the hole in the chassis rail.
On side note the NZ New cars that lack oxygen sensor also have an adjuster near left strut tower (black pot with 3 or 4 wires coming of it).
I assume that is the mixture adjuster.
