AE92 Levin Smallport 4age alternator connector melted
Postby solitaire » Mon Jun 29, 2015 7:25 pm
Hi,
As in description, just saw the grey plastic cap over the electric cable the connects to the alternator (or rather bolts to the alternator) is melted in a section, like one particular part underneath is very hot, will try to get picture when it is not raining,
anyone seen this before? any idea where to start troubleshooting.
only symptoms have been a slight burning smell which i thought was just 5 years of dust burning off, other than that the voltmeter shows 14v across the battery when it's at idle, no other issues to suggest something is wrong.
AE92, KZJ120, KDJ120
solitaire
Re: AE92 Levin Smallport 4age Distributor connector melted
Postby matt dunn » Tue Jun 30, 2015 12:25 am
Wont be melted from current as there is next to no current through the connector,
so must be from external heat like from the exhaust manifold.
Postby solitaire » Tue Jun 30, 2015 1:27 am
matt dunn wrote:Wont be melted from current as there is next to no current through the connector,
It's a pretty beefy looking electrical cable, I thought they output like 70amps? (not challenging, just asking, I know you know your stuff!)
It's a pretty particular melt, i'll take a photo, it's on the intake side of the engine, i'll have a hunt for some heat sources.
solitaire
Postby Grrrrrrr! » Tue Jun 30, 2015 2:42 am
70A distributor.. no..
70A alternator. now that would make sense.
Grrrrrrr!
Postby solitaire » Tue Jun 30, 2015 6:33 am
Grrrrrrr! wrote:70A distributor.. no..
Aaarrrggghhh sorry massive typo, long day. I meant alternator, very sorry,- original post should be alternator, not distributor :(
solitaire
Postby Stu- » Tue Jun 30, 2015 9:48 am
The reason the distributor wiring looks beefy is that its shielded which protects the trigger signal wiring from electrical interference. Actual voltage induced by the pickups is very low and current is minimal.
Project Thread
Stu-
Postby solitaire » Tue Jun 30, 2015 11:55 am
updated OP to read alternator rather than distributor :D
sorry for confusion.
solitaire
Postby matt dunn » Tue Jun 30, 2015 7:41 pm
OK, yes have seen that, there will be a bad connection between the alternator and the lead.
Best thing to do it take both nuts off the alternator stud and replace them,
and file or sand the terminal until it is shiny, or replace it,
as it will only get worse and eventually burn the rectifier.
Have seen it a few times before.
Postby solitaire » Tue Jun 30, 2015 8:20 pm
matt dunn wrote:OK, yes have seen that, there will be a bad connection between the alternator and the lead.
Hmm, just replaced faulty rectifier :?
Will do that, many thanks for your help.
solitaire
Postby matt dunn » Tue Jun 30, 2015 8:27 pm
solitaire wrote:Hmm, just replaced faulty rectifier :?
The actual cause of the problem is usually due to the fact the nuts were not clean enough
or tight enough when put back together,
so if you have just done the rectifier either the problem was already there and may have burnt your last one,
or possibly has been caused during reassembly after replacing it.
Re: AE92 Levin Smallport 4age alternator connector melted
Postby solitaire » Wed Jul 01, 2015 12:15 am
So the nut was effectively heat welded to the stud, which proceeded to snap off... which was not fun at 8.30pm when i had 90km return commute in the morning.
Managed to rangi the housing slightly to let me go lower on the snapped stud, sanded all the contact points back to shiny (they were filthy, really bad, no idea how i missed it) and reassembled.
Back up and running now, voltage across the battery at 1100rpm is 14.75V - sound ok? I'm not sure what it should really be, i think it's slightly up on what it was (14.5V from memory)
solitaire
