Had CEL today when my car decided to cough and splutter on start up, revs bounced around, then immediately shut off. I left it a minute and it restarted.
Went to look for the little diagnostic box and for the life of me couldn't find it.
Do the NZ new versions even have diagnostic boxes? I see there is three yellow plugs coming off a loom by the passenger side windscreen. Looks like two plug into each other, and the other one has a couple of slots with contacts in it. Is that some kind of ancient diagnostic tester?
Diagnostic box in a NZ AE82 GT
Re: Diagnostic box in a NZ AE82 GT
Have a look at this: Toyota diagnostics
Sweet will have a look, thanks.
- spoonza6
- Toyspeed Member
Check wiring on the map sensor.
Make sure all connected properly
Mine did the same and I found it was that at fault
No3 is diag port apparently.
diagnostic terminals should be high on passengers side firewall, near wiper motor and yep looks like no. 3 above
You can also just bridge the terminals down at the ecu if needed
Project Thread
Project Thread
