It continues. 4age vs. b16a
JT
Contact:
Post by JT »
Loudtoy wrote:
matt dunn wrote:
non_vtec wrote:, 15.25mm lift cams, ..
Lol @ trying to fit them in a 4AGE
Come on it's just a simple matter of 10-15 headgaskets at once jeez think outside the square :lol:
and with the super low compression you'd be able to run massive boost :wink:
Dragger_Dan
Post by Dragger_Dan »
RS13 wrote:
non_vtec wrote:The car is running a custom crank, rods, pistons, by all accounts its 2.3litre, 15.25mm lift cams, custom head work, roller rockers etc etc.. it runs a custom 4spd gbox using an H22 housing, ITB's, Hytech side exit header, race gas, 750kg with driver..
You could make any 4 cylinder motor fast if you spent as much money and time as these guys do.
Post Reply
