hmmm, found a vacuum hose...
Post Reply
AXNGRL
Post by AXNGRL »
Ok, 10 points for whoever can tell me where this hose is supposed to connect to...
AXNGRL
Post by AXNGRL »
Come on, someone must know!
Further info since pics aren't very clear:
Its on the firewall side, top right of rocker cover, there are 2 hoses that sit on top of each other, its the bottom of the 2... 20v silvertop levin...
AceSniper
Post by AceSniper »
thats one hell bad pic :P
but semi looks like the hose my vacume guage is on...
Ill have a look inawhile an re-post if sum1 dosnt beat me
AceSniper
Post by AceSniper »
okies...
its the middle size one outa the 3 aye?
It goes on to that group of steel tubes that have heaps of vacume hoses connected... then from there goes back to rubber and it grouped with a 2nd tube the same size that looks like its hooked to the powersteering.. well down there...
But if u just have a small bit of rubber pipe... ya just needa take a look at that group of steel tubes that are bolted on with all the vacume hoses connected just below and back abit from the lift hook, there bolted to the plenum.
was this ur prob at the drags? *finks i shoulda come over an asked*
AXNGRL
Post by AXNGRL »
sounds like you could be right, squid did mention that the hose joins on at the top (in bad picture) & then goes down into thin metal pipes, its joined on to the pipes, just need to know where it finishes its circuit, its quite a long hose & we found it tucked down the back of the engine by the firewall...
AXNGRL
Post by AXNGRL »
Yes, it was my problem at the drags :(
This is causing the car to idle rough as guts & die whenever you stop... ie, traffic on way to work was a biarch. We currently have the hose blocked off with tape & car seems to run fine...
GTCRSHR
Post by GTCRSHR »
on my old ae82 corolla it did the same thing as that sounds really bad
but still goes and eventually cuts out
idals around the 500 mark right ?
it went into the TVIS unit on the old 4age
not much help but u never know ?
AceSniper
Post by AceSniper »
itll make ya car run shit... coz its letting air in = run lean (i think)
anyway from what I could see with out pulling stuff apart it ran from that metal pipe with another hose from that area down to that bump in the firewall (think its sum kinda cover) by the steering rack... so im guessing its todo with the powersteering? not much else down there it can hook to
AXNGRL
Post by AXNGRL »
my silvertop doesn't have TVIS... but cheers anyway :D
AXNGRL
Post by AXNGRL »
failing that, anyone got a 94 silvertop in the east auckland area that we could come & have a look at?
AXNGRL
Post by AXNGRL »
any takers?
*bats eyelashes*
92GTApex
Post by 92GTApex »
Ill go and have a look at mine tomorrow when theres some light...
Its not a facelift 20valve but that wont make any difference(well shouldnt do anyway :lol: )
Logan[/quote]
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
GTCRSHR
Post by GTCRSHR »
i have a 94 fxgt with a silver top ... pm me if you want to come have a peak and am out east
AXNGRL
Post by AXNGRL »
you've got mail :)
Nathan Young
Post by Nathan Young »
if you havent tryed this already and the hose is not to long it should naturally go some were close to were it came off only catch is it mite of turned on other end. had a simler prob got a tourch and carfully looked where hose went as i turned it dident take me to long to find.
hope this is some help probably not but good luck anyway.
AXNGRL
Post by AXNGRL »
its quite a long hose & it was tucked down & through other hoses on the firewall side, with nothing obvious in the general vicinity to attach it to... will see if looking at another car gives us more clues... :D
Nathan Young
cool just thinking if ever happens again at drags try doing the damsel in depress thing you will have so many guys trying to help will be fixed in know time :wink:
AXNGRL
Post by AXNGRL »
:lol: :lol: :lol:
AceSniper
Post by AceSniper »
as iv said both hoses (the one it runs down beise) go down to that bump at the bottom of the firewall on the drivers side... (powersteering?) but yea may have to go under the car to see it clearly...
Post Reply
