The place for all technical car discussions. If you haven't already, read our
Disclaimer first!
d1 mule
Posts: 1790 Joined: Sun Dec 18, 2005 8:32 pm
Contact:
Post
by d1 mule » Mon Sep 17, 2007 10:41 am
had anyone had any experience in turboing a N/A 1JZ?? how do they go? whats involved?
im asking as iv decided to sell ma GZ10 to pay back a couple of debts (after 5k adjustables etc) and im thinking of importing either a JZZ30 or a JZX90 both manual and just turboing the stock engine for a bit.
Iv got a complete 1jzgte loom and comp and a night parts flywheel, one of marks adapter plates a auto belhousing ect sitting in the garage or would it be better buying a turbo auto one and converting it to manual? as manual turbos are a whole bunch more expensive.
Mr.Phreak
Posts: 2700 Joined: Wed Jan 26, 2005 5:10 pm
Contact:
Post
by Mr.Phreak » Mon Sep 17, 2007 1:29 pm
As far as I'm aware there is no N/A JZZ30 Soarer
There are the JZZ31's but they run the 2JZ-GE as opposed to the 1JZ
d1 mule
Contact:
Post
by d1 mule » Mon Sep 17, 2007 2:26 pm
oh ok sweet thanks
DFECTED
Posts: 411 Joined: Fri Sep 27, 2002 11:59 am
Post
by DFECTED » Mon Sep 17, 2007 8:32 pm
do you want to sell the 1jzgte loom?
I was running a 1jz na with turbo, made 210hp atw 11psi. ended up with detonation damage from donuts- oops
You cant use the 1jzgte loom on a 1jzge
you are better off starting with a 1jzgte anyday unless you budget is under $500
d1 mule
Contact:
Post
by d1 mule » Tue Sep 18, 2007 12:48 am
DFECTED wrote: do you want to sell the 1jzgte loom? I was running a 1jz na with turbo, made 210hp atw 11psi. ended up with detonation damage from donuts- oops You cant use the 1jzgte loom on a 1jzge you are better off starting with a 1jzgte anyday unless you budget is under $500
yeah i figured the looms are diff seeing Dizzy and coil packs etc.
as for loom not at the mo, still gotta decide what im gonna do.
mike simmonds
Posts: 134 Joined: Sun Feb 15, 2004 1:37 pm
Post
by mike simmonds » Wed Sep 19, 2007 7:32 pm
i hav a 1jzge wit loom, autobox etc for sale if u were interested. cheap
