stupid estima van ?'s......
ok, a little out there but,
i read somewhere that some estima vans come with a 2.4 supercharged 4 cylinder engine... is this correct? and if so, are the engines any good?
and they are front wheel drive arent they?
could be a different sort of swap in my ae111...
but im thinking i either read it wrong, or its a diesel or something dumb like that lol
- the fallen303
- Toyspeed Member
andyztouring
- Toyspeed Member
the 10 and 20 series Previa/estime/Emina rady rady are RWD and 4WD, the 30 series which is around 99+ i think are fwd.
strx7 wrote:the 10 and 20 series Previa/estime/Emina rady rady are RWD and 4WD, the 30 series which is around 99+ i think are fwd.
yeh fwd, and im pretty sure they are V6.
yuck, hate the thought of those vans. worked on too many maori/islander transporters and they are filled with cockroaches. *dry reaches*
Your local Hybrid Elite tech
some use the same motor as the new shape rav4's the 2.4l 4 cylinder vvti motor the other uses the 3.5 1GRFE motor which i think is rated around 200kw in the estima. its rated at 207 in the Aurion etc.
