Hiya,
My Levin recently died after a big thunderstorm, got to the car the next day to discover the battery was flat.
I replaced the battery, and while the car starts fine now the "check battery"(?) light stays on while the car is running.
I gather from my searches on here that this is an overcharging issue with my altenator, id like to check what voltage is running over the battery while its running to confirm this, could someone please tell me what "normal" charging voltage is for a 4age?
ps. the check exhaust temp light also comes on... but i binned my cat years ago?
Battery Problems
Battery Problems
AE92, KZJ120, KDJ120
- rwd_mayhem
- Toyspeed Member
- rollaholic
- Toyspeed Member
- johndoe1025
- Toyspeed Member
- Contact:
alternator light = not charging, open circuit or shrot circuit in the regulator most likely, or no output
cat light = low voltage giving false over temp reading, eg no output from alternator, enough to cause it to come up with a fault. thrunderstorm could of caused static electricity to fry something? would be very odd. see if your alternator stays warm, had one car, would charge but after sitting for ages the battery would go flat, i touched the alternator by accident, was warm when motor was stone cold... but yeah, bung alternator mate
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now
AE111 Levin BZG current! 4AGTE next? you never know....
No.
Quite a lot of the dash lights use the alternator as a bulb check function,
to make them come on to check the bulb before the car starts.
so a fault in the alt will bring on the cat light,
and in diesils, the sediment and possibly cambelt light too.
- johndoe1025
- Toyspeed Member
- Contact:
*shrugs* still gives you the same answer in the end. and i know of cars where fault lights come up due to low voltage+things not running right (eg GDI mitsis, run SUPER rich when not charging)
