turbo extractors hitting oil filter
Post Reply
tim_blair
Post by tim_blair »
i got myself some turbo extractors but when i tried to install it i found it was hitting my oil filter
my oil filter doesnt bolt directly onto the block
instead there is this alloy spacer (blacktop 4age)
its a standed item as i have seen it on many 4ages but i have also seen them without
i tried to remove it so i could put the filter directly onto the the block but it fits differntly
any susgestions as to how i can over come this problem
groupagt4
Post by groupagt4 »
remote mount your filter. I had the same issue and thats what i ended up doing
tim_blair
Post by tim_blair »
yea that what i thort but im unsure about the clearance ill get from doing it
im using one of those ssteel extractors from trademe
does yours have the alloy spacer that i mentioned?
would it be posible for you to take some pics of yours and email them to me?
Crampy
Post by Crampy »
Take that spacer off and bolt a filter relocation kit straight onto the block. You'll have all sorts of problems doing oil changes if it's going to be that close to the manifold.
TRD_ZERO
Post by TRD_ZERO »
Or you can take that alloy thing off, take threaded tube off the center of alloy thing and screw it directly into the block and the oil filter should go straight into that.
Previous:
Contact:
Post by matt dunn »
TRD_ZERO wrote:Or you can take that alloy thing off, take threaded tube off the center of alloy thing and screw it directly into the block and the oil filter should go straight into that.
yup, do that.
tim_blair
Post by tim_blair »
Yea ill try do that and use an oil relocator kit but for memory its not taht easy coz the way the spacer is fitted to the block i dont think that i can just replace the thread thing but ill have a look when i do an oil filter change
QikStarlie
Contact:
Post by QikStarlie »
yeh ya can, im using a 20v block with oil filter screwed straight to the block. think i stole the center threaded tube from a dead 16v.
themaleman
Post by themaleman »
we made this for mine
manual 80 series cruiser
4agte ae92 Levin
a15 powered sj410
CAMB01
Post by CAMB01 »
If you want to fit the filter onto the block, you will have to grab a threaded tube from a 16v block, as the 20v ones once you screw it into the block, doesnt leave enough thread to screw the filter onto. Been there tried that.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
TRD_ZERO
Post by TRD_ZERO »
CAMB01 wrote:If you want to fit the filter onto the block, you will have to grab a threaded tube from a 16v block, as the 20v ones once you screw it into the block, doesnt leave enough thread to screw the filter onto. Been there tried that.
Is that just the case with filter and not a relocator kit? because im using the threaded tube from a 20v and my relocator kit screws onto it.
Previous:
Crampy
Post by Crampy »
Contact:
Post by matt dunn »
Crampy wrote:http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Core-engine/auction-243223452.htm
Do it.
still wont work as there will be nothiing in the block for it to screw too.
You will need the threaded tube.
Try genuine, i have bought one of two over the years from the dealerships, and if you get a deal they are not too bad.
TRD_ZERO
Post by TRD_ZERO »
My oil filter relocator kit screws onto the treaded thing off 20vs though. So whos to say this one wont?
Previous:
0EBUNY
Post by 0EBUNY »
use a bluetop 16v or fe series threaded bolt to fit the oil filter......
new project
1998 toyota altezza :D where do i start plans go for miles
CAMB01
Post by CAMB01 »
TRD_ZERO wrote:My oil filter relocator kit screws onto the treaded thing off 20vs though. So whos to say this one wont?
Only if you screw the filter onto the block.
The filter will go on, but with only a few threads till it becomes tight, as the tube is too short.
Contact:
Post by Bazda »
I think I know what type of manifolds you bought.
As most people have said, remove the alloy spacer part, get the threaded tube bit out of a 16v block and screw that into the 20v block.
Use a oil filter that will fit with the manifold and turbo in place.
No need to waste you $ on an oil filter relocation kit, but ideally you should be running an oil cooler witha turbo setup!
Post Reply
