Engine Vibrates!
Post Reply
coolnik12
Engine Vibrates!
Post by coolnik12 »
Hey guys iv noticed that my engine of my trueno vibrates a lot when the car is stopped and on drive, like you can see the bonnet vibrate. When i shift it to neutral it doesn't vibrate. It doesn't happen all the time but when it does its really annoying. What could be wrong? :o
metal_sean_head
Post by metal_sean_head »
Engine mount stuffed?
VTEC: All of the lag and none of the boost.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
B1NZ
Post by B1NZ »
metal_sean_head wrote:Engine mount stuffed?
2nd'ed!
Subaru GF8 Wagon
Subaru GC8 rally car project
touge_ae101
Re: Engine Vibrates!
Post by touge_ae101 »
coolnik12 wrote:What could be wrong? :o
EVERYTHING!!!! might need a new flux capacitor unfortunately. :o
best bet of figuring this problem out is having a look under your car and trying to narrow down the problem so the helpful folk on here can help you with further queries. you will learn a lot more that way too. :D
my bet would be on either a stuffed engine mount or maybe if you have recently purchased the car, that it infact has solid mounts. in which case; take them out and put std ones back in. - so engine mounts would be the best place to start.
coolnik12
Post by coolnik12 »
Not really, checked it this morning. Seems fine. Someone told me it could be due to air not flowing through properly? Removed my POD and fitted the factory box on. Still does the same thing.
touge_ae101
you check all of the mounts? even the one at the back?
Contact:
Post by iOnic »
I think that's the engine's way of telling you that it's running. Just about every auto I've driven does similar when it's in drive with your foot on the brake - the engine is trying to work and you're not letting it.
celica_xr9145
Post by celica_xr9145 »
My Trueno done the excact same thing after i had the timing done, thought it was just an Automatic thing.
coolnik12
Post by coolnik12 »
celica_xr9145 wrote:My Trueno done the excact same thing after i had the timing done, thought it was just an Automatic thing.
My timing was done at 95,000kms
Right now its done 147945kms.
85AW20v
Post by 85AW20v »
Could also be the idle set a bit low - maybe only 100 revs - or an idle up valve not working correctly. With your foot on the brake the alternator probably loads up dropping the idle a wee bit. It'll probably get worse if you turn your lights on as well.
See ya
Simon
85 MR2 20v
Emperor
Contact:
Post by Emperor »
Yeh, a normal auto shouldn't shake like that..
My Stagea sits there as if it was turned off lol
metal_sean_head
This is a common problem with these and the only real remedy is to replace the engine with a 1uz.
89 AE92 FXGT
Big Port Redtop
TVIS!
19.8@32kph
coolnik12
Post by coolnik12 »
Emperor wrote:Yeh, a normal auto shouldn't shake like that..
Haha thats my dads prius ay. Engine start it and you dont even know if its turned on or still off!
Post by frost »
you cant check a rear engine mount just by looking at it, the rubber hides cracks really well, best way is to put it on a hoist and rock the engine back and forward to see if it peals the rubbers,
i had this problem in the girls auto ae111 and it was rear engine mount.
tsoob
Contact:
Post by tsoob »
metal_sean_head wrote:This is a common problem with these and the only real remedy is to replace the engine with a 1uz.
or strap a horey great turbo to it...
seriously tho man its gonna need to go on a hoist and have a good look around under it there, could be a number of things but engine mount is a likely culprit
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
Brawler
Post by Brawler »
my 1gge used to idel At like 1900revs, Made the whole car shake with the power lol
zing! Sig got nuked. Sorry bout that.
Post Reply
