pros nd cons of runing a oil cooler on a 4age?
was thinking about puting one one my road car nd wanted to know if others hav done this? and what they thought about it?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
- Burning Angel
- Toyspeed Member
- Adamal
- Toyspeed Member
Quirky wrote:My 4ag turbo with no oil cooler doesn't get above 98 degrees c at the drag strip.
And thats 2 hours, about 10 passes.
When and if, it reaches 100 degrees, ill probably start worrying.
Do you take it to the track at all? Sustained heavy use may make it get hotter. Or is it a dedicated strip car?
- 1I1
- Toyspeed Sponsor
- Contact:
Pffff 98degrees. I was seeing 140degrees at Manfeild after just a few laps
On the street, lucky for the car to get above 110degrees.
TRD Clicky >>Here
mark@manawatu.toyota.co.nz (Please mention Toyspeed
TRD Clicky >>Here
- tsoob
- Toyspeed Member
- Contact:
I run one on mine... But i had MAJOR heat issues, now its sweet as.
Dropped core temps by 10-15 degrees
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
15 Parkway Drive
Mairangi Bay
09 486 5317
- touge_ae101
- Toyspeed Member
- 1I1
- Toyspeed Sponsor
- Contact:
On the street it would never get that hot as it requires you to be reving the car to redline over and over again = not really something you should be doing
Riding in BZR4age's Levin I noticed that his oil temp wouldn't get above 80degrees on the street with just normal driving (has a thermostat). On the circuit no doubt it's a good idea, but if just comuting all you are going to do is keep the oil on the cold side.
TRD Clicky >>Here
TRD Clicky >>Here
- deaf_rattle
- Old Skool User!
- Contact:
yep, make sure you run a thermostat, because you dont want it taking forever getting to temperature either.
cheap thermostats can be found at www.summitracing.com
See the animal in his cage that you built. Are you sure what side you're on?
You are all c**ts, ill kill you all
supported by
Click for boobies
supported by
Click for boobies
- touge_ae101
- Toyspeed Member
1I1 wrote:On the street it would never get that hot as it requires you to be reving the car to redline over and over again = not really something you should be doing![]()
depends how you drive it on the street. in can think of a few occasions where redline has been seen for extended periods of time where i think my oil cooler would have definately helped!
- 1I1
- Toyspeed Sponsor
- Contact:
Heh, and they would have designed the oil system to be more than 3.3 litres with filter!
TRD Clicky >>Here
TRD Clicky >>Here
Under 100 deg is a good rule of thumb for everyday driving. Up to
120 deg when racing is kind of acceptable, but anything over 120 deg
should be considered too hot. The temperature at the bearins will be
quite a bit higher than the circulating oil temp, so at 140 deg your
bearings are not going to stay happy for long !! My $ 0.02 worth
Cheers... jondee86
Cheers... jondee86
spec small port, twinscrew s/c and water/methanol injection
Watch this space >>> <<<
The max i've ever seen with my oil cooler setup was 120C running around pukekohe.
- 1I1
- Toyspeed Sponsor
- Contact:
And there's a fair bit of reving done on Puke!
TRD Clicky >>Here
TRD Clicky >>Here
- Boost_4_Life
- Toyspeed Member
- Mr. Mainstream
- Toyspeed Member
- Contact:
wouldn't oil grades make a noticeable difference?
though i cant see how modding up a aw11 cooler would be too hard
75 MK2 Ford Escort L 2.1L
Various Others
Various Others
